Hi!
Sorry, my English is very bad.
I'm using progDVB 6.30 PRO with Win 7 x64.
I installed 64 bit version of ProgDVB, thats working correctly, but I can't use with 32 bit plugins (s2emu, vplug).
With ProgDVB 32 bit version works with plugins, but some channels are too slow with elacard, ati, ffdshow, Microsoft codecs too.... but it's
not a big proglem.
The main problem is occures when I'm closing ProgDVB which closing with following error:
Unexpected Memory Leak
An unexpected memory leak has occured. The unexpected small block leaks are: 189-204 bytes: Unknown x 44.
And after all saved data without channel list losts!
The card is Technisat Skystar 2 HD USB CI.
2nd running after 10 sec closing ProgDVB:
1-12 bytes: Unknown x 1
61-68 bytes: TCloseEmmPidThread x1
189-204 bytes: Unknown x2
DVBDream is working with this plugins correctly, and very fast, but some (7) dll error window occures at starting, but after work correctly.
ProgDVB starts correctly
