#1025
Aspect ratio not working properly if/when display-size is smaller than tv-picture!
Configuration here is a CRT with usually 800x600/120Hz display-size (nice for analog-TV with Chris-TV). Working fine with ProgDVB for SD-channels. But when using HD-Channels (1280x720) on 800x600 screen, aspect-ratio of 16:9 is only possible in normal screen, but neither in full-screen, nor in tv-window mode; then the prog-dvb-screen-size is 4:3 in letterbox-mode ... :(
#1027
Kakadu wrote:Aspect ratio not working properly if/when display-size is smaller than tv-picture!
You did not formulate a question right.
Aspect ratio works fine.
http://www.fayloobmennik.net/1999645
If you want to ask why it does not work for you, you had to formulate the question differently-For example, something I have not worked and I myself can not understand, please help me. :)
It is not necessary be so categorically.
#1029
OK, OK, OK ... ;) ... I'll have a look at that again in detail; but it seems to me very strange that the HD-version of a 16:9-channel comes in 4:3-letterbox mode (with black stripes) when set to 100%-window-mode, but a SD-channel comes without the black stripes in "direct" 16:9-mode (with a window in 16:9 aspect ratio) when in 800x600 screen size; but HD channel (of 1280x720) comes directly in 16:9 aspect ratio (without black stripes in 100%-window) when screen-size is set to 1280x960 or something above ... (be aware: I run an old-fashioned Cathode-Ray-Tube-Monitor on a WinXP here).
I'll do several more experiments in several screen sizes to trace that down in detail; the CRT allows 800x600@120Hz, 1024x768@100Hz, ... up to 1600x1200@ some eye-killing 60Hz or something about that, and be aware that a 64bit Vista cannot run faster than 85Hz, you'd have to use 32bit Vista to run a CRT it in 100Hz or 120Hz ... (only Micro$oft knows why that restriction exists) ...
#1030
:| i just delete a channel from list and also delete it from undelete windows, now when i scan that frequency the channel not add in the list, WTF , i have this problem long time. how can i back to list deleted channel ? when i scan a FRQ in scan window i can see the channel are founded but it not add to list. :(
duh bad english
#1032
Prog wrote:Please use normal scanner or/and look what list receive new channels. I think channels after manual scanner added to other list.
the only way i success to back channel to list was to use : channel search > (WDM) Skystar 2 TV PCI > and scan completly hotbird satellite. after that a window opened and show me which channel undeleted & new & lost....
but when i use manual search , progdvb find all channels but not add them to list(them which are not in list)
and im sure its not added to other list. i only have Hotbird list and after manual scan i searched deleted channel name but cant find....
another problem is, sometimes when i click on a channel , pogdvb open it but interesting progdvb also delete it from list!!!!
thanks for quick reply and sorry for my bad English.
#1033
another problem is when channel properties window is open and i try to delete or rename ... a channel from list , progdvb will crash....
#1035
Prog wrote:Please send me files from Logs\reports after crash
done, 'properties channel' window is open and i delete a channel , as you can see in picture number 1 , you see progdvb crashed, after timer of crash window, progdvb try to restart but a window will open and say"ProgDVBNet has stopped working" (picture number 2), and i should click close the program, 'ProgDVBNet' will close but 'ProgDVBEngineRun' still is open in task manager (playing channel sound with out video!!!) (picture 3)
and Logs folder are uploaded(i cant attach pictures because pixels was big). thanks
Logs folder after crash : http://up98.org/upload/server1/02/j/6du ... dckllu.zip
Picture 1 : http://up.vatandownload.com/images/epr5 ... ky6exw.jpg
Picture 2 : http://up.vatandownload.com/images/s0yu ... lu61d7.jpg
picture 3 : http://up.vatandownload.com/images/jadunojvmbwl2ukx.jpg
Logs.zip
(6.88 KiB) Downloaded 404 times
