#1066
Prog wrote:I need ProgDVBEngine.log file...
Until I've installed v.6.86.4 everything worked fine. Description:
It takes approximately 5sec from program start and then the app freezes. Between start and 5th second there is no video, only audio. When program freezes I noticed that progdvbengine.log becomes bigger and bigger. CPU load then is at 90-100% level. I had to force kill the progdbbnet process because it couldn't stop automatically.
CODECS choosed in program : FFDSHOW video & audio.
In v. 6.86.3 everything works fine. Now even with the newest version 6.87 problem still exists and I can not describe this problem better.
In my opinion Mister programer should check changes between 6.83 and 6.84 and start to search problems there...
Logs.7z
Logs
(229.12 KiB) Downloaded 291 times
#1069
Prog wrote:What about (c) prerelease?
I'm using ArcSoft HD Audio Decoder for AC3 and same for MPEG-2 Video (ArcSoft), so , now with 6.87C have new problem even with MPEG audio channel , the problem is when i try open a channel first time i click on it tuner lock on it but not show the channel (time shift not runing) when for second time i try to open that channel , it open successfully. as you can see in this photo tuner are locked on Manototv1 but not showing anything : http://www.padideh1.nl.am/files/files/pp.jpg
using this codecs from old time was working great until now...
same problem for x264 channels when using mpeg audio track, but when i change audio to ac3 have video normally but with out voice (changed a lot of codec for ac3 but no sound)...
all with prog demux
hope im helping
#1072
still having problem with ac3 (no sound).
and some times remote keys (mouse & keyboard & rc) not work...
#1075
Fullscreen problem on Windows 7 with custom DPI.
Personalize --> Display --> Set custom text size (DPI) --> 200%, uncheck Windows XP style.
Now in full screen taskbar is always visible and cannot be completely hidden.
ProgDVB v6.86.4, EVR CP, LAV Filters
MPC-HC, XBMC, TMT have no such problem, only ProgDVB.
#1077
dmart: what taskbar you mean? 200% is very exotic.
Windows taskbar is displayed on top of ProgDVB in fullscreen. I am not sure if 101% would give the same results. I run ProgDVB on my HTPC connected to TV, therefore 200% is required to be able to see OS menus etc. from 3 meters distance.
#1079
dmart wrote:Fullscreen problem on Windows 7 with custom DPI.
same problem here, but i use default DPI and in full screen mode windows taskbar is on top of video
dear prog about ac3 codec , was using arcsoft and it was okay now at this version none of ac3 decoder work...
