#1145
hello dear Prog, i having this new error when progdvb crash occur and restart : http://www.p30up.ir/up/tf0bbcvgyw8is4nly07l.jpg
after progdvb restart, give this error to me on every mpeg2 channel with codec "Microsoft DTV-DVD Video Decoder" as you was suggested. to fix and stop this error i should close ProgDVB and start again or click on Stop button under timeshift and select channel again.
no such problem with "ArcSoft Video Decoder" , I'm using "Enhanced Video Renderer" , in stability mode.
for test you can set MPEG2 with "Microsoft DTV-DVD Video Decoder" and "Enhanced Video Renderer" , in stability mode Then should try to terminate "ProgDvbEngineRun.exe from task manager , crash will happen then you will see this error.
#1147
Prog wrote:Windows8? It looks like MS remove codecs from some version of OS.
nope , its windows 7 - 32bit. working perfect before with "Microsoft DTV-DVD Video Decoder" but now after progdvb crash showing error .
#1149
Prog wrote:I am not have any problem with ProgDVB and win7 codecs...
this guy have same error but on win8 : viewtopic.php?f=2&t=8345
well , me and probably more people having this problem , this is not a good reason which you haven't problem and every things is ok !!!!
so this error is happening and a good programmer will think why this happening. did you try to terminate "ProgDvbEngineRun.exe" from task manager. this will cause crash and after restart, the error will show when using "Microsoft DTV-DVD Video Decoder"....
BTW , this time it after crash it happened even with arcsoft codec , PIC : http://www.p30up.ir/up/euve3m9utlvitlhaqug.jpg
and logs are attached:
Logs.zip
this error : http://www.p30up.ir/up/euve3m9utlvitlhaqug.jpg
(501.31 KiB) Downloaded 306 times
#1153
@V.Zhukoff : yes , I'm using Prog Demux.
@Prog : tested with video renders: " EVR Custom Presenter " and " VMR-9 Renderless " , same error after crash and restart ... with "Microsoft DTV-DVD Video Decoder"
using ProgDVB 6.90
any thing less you need i will help you ;)
update: also changed demux to ArcSoft & Cyberlink , same error happening :shock:
#1155
Prog wrote:Try EVR at first.
i always using EVR , first time i told you this problem i was using EVR , BTW same with EVR.
