#1187yep, signal level is back with 6.91.2d ...
#1188yeap , now signal lock perfectly and we can scan again ... thanksProg wrote:I hope fixed in (d)
ProgDVB6.91.2d.Pro >> Signal : Locked
#1189Hi! I testing progdvb standard before buying the full version.
My equip: piv 3,4ghz northwood. 4gb ram,ati 4670 agp.win xp
pinnacle/Pctv 310i analog/digital.
skystar hd2(I updated from skystar 2 yesterday).
The problems I found: I have L=0 in some TDT Freeview channels and quality 100%.The channels work.
progdvb close herself.when it closes with skystar hd2,the 310 can't be started until I reset the computer
Sometimes,progdvb freeze when I scan the 246 transponders in tdt spain(310i).And I need use ctr+alt+supr to close progdvb.
Skystar HD2 lost signal in s2 transponders and other s after time of use.(with last technisat drivers).I read other people in the forum with this problem.
I testing now a configuration without use iturner request.And with 1.1.2.700 driver for the skystar hd2.
At the moment it works.(fingers crossed) except L=0
This is the drivers I testing : http://www.azurewave.com/Support_Utility_Driver.asp
winxp,pctv 310i analog,fm,DVB-T,skystar HD2 + CI dvb-s2
#11901. Install last ProgDVB version (.3)
2. It is normal if ProgDVB request restart PC after crash. Half of BDA drivers in world have this bug.
#1191I using the últimate versión.The alternative drivers of skystar hd2 solve the problems with s2 tranponders.(I happy)
But the program crashed.At least this time.He report me an error.It crashed using the 310i.
A windows appear and destroyed the final of the movie And progdvb closes.
"Microsoft visual c++ runtime libray"
"Runtime error!"
"Program C:\archivos de programa\progdvb\progdvbnet.exe"
"This aplication has requested the runtime to terminate it in a unusual way. Please contact the aplication's support team for more information".
Progdvb no generate a log in the log carpet
"Runtime error!"
#1192Check Settings->Options->Debug->Enable logs.
#1193I dont know for sure, but it seems logs are cleared every start-up of Progdvb. If this happens, crash messages will be deleted, making logs useless for anormal ending. So, in case of bad ending, logs should not be cleared
Will check this later...
#1194O.k. It take much time to generated the problems.
This time it only auto exit.No menssage of c++.
There are my logs.
I not 100% sure,but late yestarday I tried the 6.91.0.And it no exit or print the c++ menssage.
There are my logs.
- Logs.rar
- (72.84 KiB) Downloaded 384 times
#1195Need reports directory also.
ps: You have damaged traffic. May be signal too low.
#1196Report directory is empty.This is the cause I no include it.
I was ejecute a antivirus scan.Maybe it affect a litte to cpu and the traffic.
Can be low signal crash dvb?.I expected pixelation issues with low signal not crash program.
The second intent appear the c++ message.
The logs.(report carpet is empty so i not include it).
I will try the other old version to confirm whether it works or not.
edit:it crash
edit2:its rare,I desmarqued reset the aplication after crash.And it work! no more crash!.Maybe its exit herself because a ghost crash
In the other hand I noted progdvb duplicate a lot of channels. in the satellite list after a search.
edit:it crash
- Logs.rar
- (44.33 KiB) Downloaded 365 times
#1197I have a very rare problem.
Progdvb bloqs me the alt Gr key the left control key and the left shift key.with universal hid remote control.
I can`t write the arroba without close progdvb completly(icon included).
XD
XD
#1198You must change RC module or check "only foreground" in HID module
#1199At least from the last 2 versions (6.91.3/4) OSD is not showing trafic info, neither video or audio types. Please, fix it.
By the way, Prog, cant you include the croma compresion (4
x) info in the OSD? One reason to use a DVB card is to see 4:2:2, so it is a satisfaction to know we opened this kind of channels
#1200I found the mine OSD problem origin. It is that portuguese language is not more a option in Progdvb. Anyway, the old language files (pt-Br directory) already present keeps after latest updates. But selecting it, its "default OSD" skin doesnt work correctly (with newest versions).
Normally I dont use pt language, so only some days ago noted the issue.
@Prog, If you choose to activate Pt-Br again, I can help to translate or revise it.
PS. I just noted that Spanish and French are also missing in languages
