#1263
Not lucky with c++ error.I think something is wrong with the skystar HD2.
I returned to the original driver from technisat.In principle. the c++ error no appears(is not 100% sure).But the old error appear,progdvb lost signal after a time of use. :(.(this not happens with the azureware alternative drivers but with c++ error)
After time of switch to tdt with the 310i,magically signal return to the skystar HD2 ¿?¿?.(normally it not returno :P until i reset progdvb)
Damm,I not buy the pro versión,Because I can not make it work :(.
I testing it now.This is the logs,with the lost signal in satellite after time view the tdt.But I continue using progam now to view if c++ error appears.
winxp,pctv 310i analog,fm,DVB-T,skystar HD2 + CI dvb-s2
(41.03 KiB) Downloaded 324 times
#1265
Finally,I think i found a litte light at final of the tunnel.
I remember,the arcsoft codec crash sometimes when I change channel and I use wmr-9.(because of that I use (wmr-7).I search the version of the codec.And I discover I have a little old version,2.28.496 instead 2.28.497 I download the last version.And at the moment after 3 hours no more c++ error with azureware driver.
I need use the arcsoft,because is the only codec work perfect with dxva(in xp).
I crossfingers. :mrgreen:
#1266
I am new to this forum and software but prior to purchasing the software I would like to test the recording /scheduling function.
I downloaded the professional version ProgDVB + ProgTV x32 Professional
I received a 7 day trial code and pasted this into the dialog box and I got the message 'code sucessful relaunch program'. When I did this the program just brought up the registration dialog box again asking for the code and would not let me use the software.
I unstalled the software and reinstalled but still got the same message.
How can I get out out of this loop ?
I have a TBS 6620 pci card and I am running windows 7
thanks
Dave
#1272
I just bought your product to download PLS + MIS progarm,
But I found there is a problem, when I using the record does not contain the PID of the audio,
when I playback there is no track to hear any sound,tested all decoders,
I using the PID record one of PID,playback is Normal.
How to deal it? Thank you!
