#1427
hi prog, today i tried to install ProgDVB6.97.4a.Pro but it always stock at 40% refreshing .net assembleys... as you can see in this photo
http://p30up.ir/images/iikhbxrhzud9b5ks2g2.jpg
i should terminate the setup from task manager and next time i open setup file it will keep giving me error that cant access files...
any how i cant install new version. any clue ??
***Edit : ProgDVB6.96.2Pro installed normally. currently using ProgDVB6.96.2Pro, I'm waiting for new release ....
#1428
ProgDVB6.97.4e.Pro , cant install this version the 'e' pre-release stay (stop) at 10% of updating new setup.... picture:
http://p30up.ir/images/v3hthi4ozr69vmbit6m8.jpg
but i see some changes in counting percent of Refreshing of .Net assembleys cache...
installed this version successfully with no problem > ProgDVB6.97.2Pro
#1430
Prog wrote:fixed in new prerelease.
yes and thanks :) fixed installed successfully ProgDVB6.97.4 F .Pro
this is the detail of installation if you need, saw some error in some lines:
Output folder: C:\Program Files\ProgDVB
Create folder: C:\ProgramData\ProgDVB\Channels
Create folder: C:\ProgramData\ProgDVB\Record
Create folder: C:\ProgramData\ProgDVB\SnapShots
Create folder: C:\ProgramData\ProgDVB\ts
Create folder: C:\ProgramData\ProgDVB\Transponders\TerFiles
Create folder: C:\ProgramData\ProgDVB\Transponders\CabFiles
Create folder: C:\ProgramData\ProgDVB\Transponders\IPTV
Create folder: C:\ProgramData\ProgDVB\Transponders\InternetTV
Extract: ChannelNameTable.txt
Extract: CityList.txt
Extract: GuideStyles.txt
Extract: credits.txt
Extract: help.chm
Output folder: C:\Program Files\ProgDVB\ChLogos
Extract: images.base
Extract: readme.txt
Output folder: C:\Program Files\ProgDVB\Channels
Output folder: C:\Program Files\ProgDVB\Modules
Output folder: C:\Program Files\ProgDVB\Modules\boot
Extract: SC_MAIN.MC
Output folder: C:\Program Files\ProgDVB\Modules\boot\24
Extract: Boot_up.axf
Extract: Dpram
Extract: Root
Output folder: C:\Program Files\ProgDVB\Modules\boot\nova
Extract: dsp_usb.bin
Output folder: C:\Program Files\ProgDVB\Modules\htdocs
Extract: pms4_busy.htm
Extract: pms4_index.htm
Extract: pms4_not_found.htm
Output folder: C:\Program Files\ProgDVB\Plugins
Extract: readme.txt
Output folder: C:\Program Files\ProgDVB\Plugins\pip01
Output folder: C:\Program Files\ProgDVB\Plugins\pip02
Output folder: C:\Program Files\ProgDVB\Plugins\pip03
Output folder: C:\Program Files\ProgDVB\Record
Output folder: C:\Program Files\ProgDVB\Skins
Extract: Aero Black.hd.xsosd
Extract: Aero Black.xsosd
Extract: Black Transparent.hd.xsosd
Extract: Black Transparent.xsosd
Extract: Default.hd.xsosd
Extract: Default.xsosd
Extract: Skin1.xskin
Extract: Sunny.hd.xsosd
Extract: Sunny.xskin
Extract: Sunny.xsosd
Extract: WMP 11.xskin
Extract: Winamp Style.xskin
Extract: windows 8.xskin
Output folder: C:\Program Files\ProgDVB\Transponders
Extract: all.list
Extract: base.zip
Output folder: C:\Program Files\ProgDVB\Transponders\ATSC
Extract: list.txt
Output folder: C:\Program Files\ProgDVB\Transponders\CabFiles
Extract: all.list
Extract: userlist.txt
Output folder: C:\Program Files\ProgDVB\Transponders\IPTV
Extract: DiselTV.m3u
Extract: Hansenet IPTV.m3u
Extract: Kirov - jDSL.m3u
Extract: Moscow - Corbina.m3u
Extract: Moscow - CrossNet.m3u
Extract: Moscow - IskraNet.m3u
Extract: Moscow - NetBynet.m3u
Extract: Moscow - Qwerty.m3u
Extract: Moscow - Stream.m3u
Extract: Moscow - YaolTV.m3u
Extract: Moscow - iflat.m3u
Extract: Novosibirsk - Kabelnoe Internet TV.m3u
Extract: Novosibirsk - Sibirtelecom.m3u
Extract: ProgMediaServer.m3u
Extract: Rostov-on-Don.m3u
Extract: Ryazan - Interlink.m3u
Extract: SPb - Eltel.m3u
Extract: SPb - WestCall.m3u
Extract: Saratov - jDSL.m3u
Extract: Spb - Nnz-Home.m3u
Extract: T-Home Entertain.m3u
Extract: Voronezh - Domolink.m3u
Extract: Voronezh - Freedom.m3u
Extract: list.txt
Extract: multi.tv.m3u
Extract: nms-abvTV.m3u
Output folder: C:\Program Files\ProgDVB\Transponders\InternetTV
Extract: InternetRadio.itv
Extract: InternetTV.itv
Output folder: C:\Program Files\ProgDVB\Transponders\TerFiles
Extract: all.list
Output folder: C:\Program Files\ProgDVB\ar-TN
Extract: MainFormStrings.txt
Extract: ProgDVBNet.CD.resources.dll
Extract: ProgDvbNet.resources.dll
Output folder: C:\Program Files\ProgDVB\de-DE
Extract: EpgStrings.txt
Extract: ProgTvStrings.txt
Output folder: C:\Program Files\ProgDVB\et-EE
Output folder: C:\Program Files\ProgDVB\fa-IR
Extract: Readme.txt
Output folder: C:\Program Files\ProgDVB\hu-HU
Output folder: C:\Program Files\ProgDVB\it-it
Output folder: C:\Program Files\ProgDVB\pl-PL
Output folder: C:\Program Files\ProgDVB\pt-BR
Output folder: C:\Program Files\ProgDVB\ru-RU
Extract: help.chm
Output folder: C:\Program Files\ProgDVB\tr-tr
Output folder: C:\Program Files\ProgDVB\uk-UA
Extract: 10moons.Device
Extract: AVerM199.Device
Extract: Anysee.eBDA
Extract: AverMedia.eBDA
Extract: Azurewave.eBDA
Extract: BDA.Device
Extract: DVBSDLL.DLL
Extract: DVBSky.eBDA
Extract: DigitalDevices.eBDA
Extract: DvbWorld.eBDA
Extract: Geniatech.eBDA
Extract: GotView.eBDA
Extract: Hauppauge.eBDA
Extract: KWorld.device
Extract: NetClient.Device
Extract: Nova_PCI.device
Extract: Nova_USB.Device
Extract: Nova_USB2.Device
Extract: Omicom.eBDA
Extract: Omicom.ini
Extract: PidRecorder.module
Extract: Pinnacle.Device
Extract: ProgMediaServer.Module
Extract: Sky2PCAVSrc.ax
Extract: SkyStar2.Device
Extract: TBS.eBDA
Extract: TBS.eBDA2
Extract: TBS.ini
Extract: TSReader.Device
Extract: TbsCIapi.dll
Extract: Technotrend.eBDA
Extract: Technotrend.eBDA2
Extract: Technotrend.ini
Extract: Tevii.eBDA
Extract: TongShiProgDVB.device
Extract: TwinHan.device
Extract: anysee.Device
Extract: flv.trf
Extract: irremote.DLL
Extract: kworld.eBDA
Extract: mp4.trf
Extract: newmi.device
Extract: ogg.trf
Extract: skydll.dll
Extract: ttBdaDrvApi_Dll.dll
Extract: ttlcdacc.dll
Extract: ttusb2acc.dll
Extract: ttusbacc.dll
Extract: wmv.trf
Extract: SC_MAIN.MC
Output folder: C:\Program Files\ProgDVB\Filters
Extract: ElecardDemux.reg
Extract: LC.dll
Extract: License.rtf
Extract: elaudec.ax
Extract: em2vd.ax
Extract: empgpdmx.ax
Extract: register.cmd
Extract: thsource.ax
Extract: unregister.cmd
Output folder: C:\Program Files\ProgDVB\Vis
Extract: Acidspunk.svp
Extract: CosmicBelt.svp
Extract: CosmicBelt.txt
Extract: LightMagick.svp
Extract: PixelBallet.svp
Extract: RabbitHole.svp
Extract: SpectralTrip.svp
Extract: corona.svp
Extract: readme.txt
Extract: starwave.svp
Output folder: C:\Program Files\ProgDVB\Vis\Aorta
Extract: Aorta.svp
Extract: Aorta.txt
Output folder: C:\Program Files\ProgDVB\Vis\Starlight Aurora
Extract: vov-sa172.svp
Extract: vov-sa172.txt
Output folder: C:\Program Files\ProgDVB\RemoteControl
Extract: AzureWave.HidPreset
Extract: DirectInput.RcModule
Extract: Microsoft.HidPreset
Extract: Technisat.HidPreset
Extract: UnivHidRemoteControl.RcModule
Extract: WinLircClient.RcModule
Extract: readme.txt
Extract: ProgLauncher.exe
Extract: IPDev.SkinEditor.Design.dll
Extract: IPDev.Skins.dll
Extract: EngineApiWrapper.dll
Extract: ProgDvbNet.exe
Extract: ProgDvbNet.Win.dll
Extract: ProgDvbNet.bc.dll
Extract: ProgDvbNet.CD.dll
Extract: SkinEditor.exe
Extract: ProgGuide.exe
Extract: Ionic.Zip.Reduced.dll
Extract: ProgDVBNet.Base.dll
Extract: ProgDVBNet.EPG.dll
Output folder: C:\Program Files\ProgDVB\Microsoft.VC90.CRT
Extract: Microsoft.VC90.CRT.manifest
Extract: msvcm90.dll
Extract: msvcp90.dll
Extract: msvcr90.dll
Extract: ProgDvbEngineRun.exe
Extract: Scheduler.dll
Extract: ProgDvbService.exe
Extract: ProgTV.exe.config
Extract: ProgTV.exe
Output folder: C:\Program Files\ProgDVB\Themes
Extract: Copy of Default.xaml
Extract: Grey.xaml
Extract: readme.txt
Extract: ProgDvbEngine.dll
Extract: Uninstall.exe
Execute: "C:\Windows\regedit.exe" /s "C:\Program Files\ProgDVB\Filters\ElecardDemux.reg"
Refreshing of .Net assembleys cache. 0%
Microsoft (R) CLR Native Image Generator - Version 2.0.50727.5420
Copyright (c) Microsoft Corporation. All rights reserved.
Uninstalling assembly C:\Program Files\ProgDVB\ProgDvbNet.exe
Error: The specified assembly is not installed.
Uninstalling assembly C:\Program Files\ProgDVB\ProgGuide.exe
Refreshing of .Net assembleys cache. 2%
Refreshing of .Net assembleys cache. 5%
Microsoft (R) CLR Native Image Generator - Version 4.0.30319.17929
Uninstalling assembly C:\Program Files\ProgDVB\ProgTV.exe
Refreshing of .Net assembleys cache. 7%
Refreshing of .Net assembleys cache. 10%
Compiling assembly C:\Program Files\ProgDVB\ProgGuide.exe (CLR v2.0.50727) ...
ProgGuide, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null
Compiling assembly ProgDVBNet.EPG, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null (CLR v2.0.50727) ...
Compiling assembly ProgDVBNet.Base, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null (CLR v2.0.50727) ...
Compiling assembly IPDev.Skins, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null (CLR v2.0.50727) ...
Compiling assembly Ionic.Zip.Reduced, Version=1.9.1.5, Culture=neutral, PublicKeyToken=edbe51ad942a3f5c (CLR v2.0.50727) ...
Refreshing of .Net assembleys cache. 40%
Compiling assembly C:\Program Files\ProgDVB\ProgDvbNet.exe (CLR v2.0.50727) ...
ProgDvbNet, Version=6.97.4.5, Culture=neutral, PublicKeyToken=null
Compiling assembly ProgDvbNet.CD, Version=1.3.1.0, Culture=neutral, PublicKeyToken=null (CLR v2.0.50727) ...
Compiling assembly EngineApiWrapper, Version=1.6.1.0, Culture=neutral, PublicKeyToken=null (CLR v2.0.50727) ...
Compiling assembly ProgDvbNet.bc, Version=1.4.1.0, Culture=neutral, PublicKeyToken=null (CLR v2.0.50727) ...
Compiling assembly ProgDvbNet.Win, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null (CLR v2.0.50727) ...
Refreshing of .Net assembleys cache. 60%
2> Compiling assembly ProgDvbNet.bc, Version=1.4.1.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
1> Compiling assembly C:\Program Files\ProgDVB\ProgTV.exe (CLR v4.0.30319) ...
2> Compiling assembly EngineApiWrapper, Version=1.6.1.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
2> Compiling assembly ProgDVBNet.Base, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
2> Compiling assembly IPDev.Skins, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
1> Compiling assembly ProgDvbNet.Win, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
#1431
here is another bug, when i open ProgDVB and splash-screen is showing (loading to open progdvb), meanwhile again quickly i double click on ProgDVB icon (open another ProgDVB) it will open multiple process and this will crash progdvb and cause other problem & activation(license) problem... as you can see in this photo :
http://p30up.ir/images/f6mhrkitiy8bm7zoq6f.jpg
- no tagged pics, PLEASE. Use links instead -://p30up.ir/images/f6mhrkitiy8 ... .jpg[/img]
after closing progdvb and all Recovery windows if i open ProgDVB there might be some problem...
but when progdvb is fully open and i open another progdvb , the running progdvb will pop up and it is good (ok), no more multiple process. so this problem only happen when splash-screen is showing and loading for open progdvb...
this is old problem.
ps: i'm using 6.97.4 F Pre-release but in about windows and splash-screen its showing : 6.97.4e
#1432
I get an error at the latest Progdvb pro version: 7.01 (I use 32bit version on 64 system)
At start a message appears:
"ProgDVB Engine API Except in ProgDvbEngine:Engine_About"
When I press ok ProgDvB starts and freezes.
Windows 7 64bit system
Skystar 2 HD DVB-S PCI card
Btw the link in startmenu still says "ProgDvb 6" ;)
#1434
whoops wrote:I get an error at the latest Progdvb pro version: 7.01 (I use 32bit version on 64 system)
I get the same thing.
Windows Vista Basic 32bit
TBS6925 PCI-E DVB-S2 Professional
#1438
Multi-Channel bug?
I notice in new versions of ProgDVB, the layout of Multi-Channels can not be set to Table/Icons option?
Only Picture in Picture option is possible.
Last good working in ProgDVB6.96.4?
MultiChannel option ProgDVB6.96.4
MultiChannel option layout ProgDVB7.02.0c not possible?
#1440
crash happened will messing around with PIP, here is the logs....
ProgDVB PIP Crash Log.zip
(46.25 KiB) Downloaded 355 times
PIP is not stable and need lot of improvement.
an idea, is it possible when we select pip ProgDVB only show the channels which are on the same transponder of the current channel???
