Please remember be. What device you have? "Satelco Easywatch" is common name of different devices.
ps: Some technotrend clone?
																																							Re: Update Problem?
#22My TV-card: Satelco Easywatch HDTV PCI DVB-C;  Similar to TechnoTrend TT-connect
							Re: Update Problem?
#23More one tecnotrend tt-connect devices... I have only DVB-S in my collection.
OK. Try remove Technotrend.eBDA, same problem? Or try take modules\boot directory from old version to new?
ps: Can you prepare logs from old/good version?
Re: Update Problem?
#24Where should I know wich Files I have to overwrite to the old version?
Deinstalling/Reinstalling BDA-Drivers was the first I tried.
Where I get the logfiles of my old version?
Re: Update Problem?
#25You can install more one version on same PC in portable mode to different and not program files directory.
Options->Debug->Logs
Re: Update Problem?
#26doesn´t work, doesn´t work, doesn´t work.... (also changeing selected directories) I´m so fed up with this (fuc.... program)
the log:
Message: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
Method: Boolean IsItYouTubeChannelTree(ChList.ChannelTree)
Stack:
bei Providers.YouTubeProvider.IsItYouTubeChannelTree(ChannelTree tree)
bei ProgDvbNet.QuickUrlPanelControl.QuickUrlTextBox_TextChanged(Object sender, EventArgs e)
bei System.Windows.Forms.Control.OnTextChanged(EventArgs e)
bei System.Windows.Forms.TextBoxBase.OnTextChanged(EventArgs e)
bei System.Windows.Forms.Control.set_Text(String value)
bei System.Windows.Forms.TextBoxBase.set_Text(String value)
bei System.Windows.Forms.TextBox.set_Text(String value)
bei IPDev.Skins.SkinTextBox.set_Text(String value)
bei ProgDvbNet.QuickUrlPanelControl.ResetDemoString()
bei ProgDvbNet.QuickUrlPanelControl.OpenUrltoolStripMenuItem1_Click(Object sender, EventArgs e)
bei System.Windows.Forms.Control.OnClick(EventArgs e)
bei System.Windows.Forms.Button.OnClick(EventArgs e)
bei IPDev.Skins.SkinButton.OnClick(EventArgs e)
bei System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
bei System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
bei System.Windows.Forms.Control.WndProc(Message& m)
bei System.Windows.Forms.ButtonBase.WndProc(Message& m)
bei System.Windows.Forms.Button.WndProc(Message& m)
bei IPDev.Skins.SkinButton.WndProc(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Extra details:
							the log:
Stack:
Extra details:
Re: Update Problem?
#28That´s what I did before I posted here. But it doesn´t work as usual. So now?
							Re: Update Problem?
#30BDA-Log:
17:41:01.122 - Start logging...
17:41:01.122 - GetBdaTunerList
17:41:01.122 - tuner Satelco EasyWatch PCI (DVB-C) - - \\?\pci#ven_1131&dev_7146&subsys_002c1894&rev_01#5&345e3eb5&0&1000e7#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{cae1e715-e724-4a90-a769-a2da237a7151}
17:41:01.132 - Satelco EasyWatch PCI (DVB-C) ex:22023 type:DVB-C
17:41:01.132 - GetInfo 1
17:41:01.132 - CreateExtApi default
17:41:01.132 - GetModuleInfo {BDA} Satelco EasyWatch PCI (DVB-C) 22023
17:41:01.132 - exIndex 0
17:41:01.132 - maxfilters 128
17:41:01.132 - caps 200304
17:41:01.132 - PossibleStart 1
ProgDVBEngine Log:
17:40:58.383 - Start logging...
17:40:58.383 -
17:40:58.383 - Start engine 6.133
17:40:58.383 - ExceptionFilter::Init. restart=1
17:40:59.263 - DevicesManager::Start
17:40:59.263 - DevicesManager::Loading...
17:40:59.263 - device BDA.Device 22023 17:40:59.343 - !!! DebugCriticalMesssages: Cannot connect network provider
Error!!!
17:40:59.343 - !!! DebugCriticalMesssages: [{BDA} Satelco EasyWatch PCI (DVB-C)] Device not started!
Error
17:40:59.343 - device NetClient.device 0 OK
17:40:59.343 - CAVManager::Init
17:40:59.394 - AV settings loaded
17:40:59.404 - VR: GUI
17:41:01.022 - Api2BaseModule::GetAdditionInfo
17:41:01.052 - Api2BaseModule::GetAdditionInfo
17:41:01.272 - DevicesManager::GetFullList 13
UI_Updating Log
1:01.032 TaskManager Init
41:02.052 Check all
41:02.052 tmp file: C:\Users\Marc-Mediacenter\AppData\Local\Temp\tmpD6B0.tmp
41:02.052 tmp file: C:\Users\Marc-Mediacenter\AppData\Local\Temp\tmpD6B1.tmp
41:02.052 Automatic updating ... 2
41:02.052 Added task.
41:02.052 Added task. Programmdateien
41:02.052 Thead started
41:02.052 versions history - http://update-progdvb.com/history.txt
41:02.262 Downloaded : http://update-progdvb.com/history.txt (versions history)- result OK
41:02.272 Deleted file: C:\Users\Marc-Mediacenter\AppData\Local\Temp\tmpD6B0.tmp
41:02.272 fileindex - http://update-progdvb.com/update_files3/filelist.txt
41:02.312 Downloaded : http://update-progdvb.com/update_files3/filelist.txt (fileindex)- result OK
41:02.322 AfterAllTasks
41:03.862 tmp file: C:\Users\Marc-Mediacenter\AppData\Local\Temp\tmpDDC3.tmp
41:03.862 Added task. EPG base loader
41:03.862 EPG base loaded -
41:03.862 AsyncEpgBaseLoader
41:03.862 AfterAllTasks
ProgDVBEngine Log:
17:40:58.383 -
Error!!!
Error
UI_Updating Log
41:02.052 Check all
