#1501
hi again. take a look at this picture : http://p30up.ir/images/ioax74pgxxmiaxzqm3z9.jpg
EPG information on timeshift bar tool tip and EPG windows are different, is this normal ? (using latest version)
and about Remove existing channel (selected transponder) and add fresh founded channels to end of the list when manual scaning a TP. can you please add this option to manual scanner windows ?
#1507
after upgrading to ProgDVB v7.06.1 in the channel list , cut & delete & Undo ... not work. cant delete a channel from list (or multiple selected) also after scan(manual or sat) channels will add again to list because progdvb think it doesn't have this channel from before (channel list old version 7.06) and add them again. i think new fresh scan and sorting is required and necessary again. is it ?
#1508
related to channel list problems, after downgrade to 7.06 version there was no channel list in program, so again installed 7.06.1 channels were back but with problem i mentioned before. so i deleted all files in channels folder and started a fresh new scan, scanned Hotbird successfully, tried to scan my second satellite Eutelsat 7E all channels founded , an empty channel list folder with name : 7.0° E :Eutelsat 7A has been created but no channel in it, tried again but founded channel not add to this list....
update:
there are two picture you might like to see:
picture.zip
(231.45 KiB) Downloaded 336 times
in channel properties window check unsource ... maked channels show up! confusing !! still delete & .... not work
#1511
let me describe the problem again. i had progdvb v7.06 with no problem, upgraded to 7.06.1
problem #1 : now if i scan channels all founded channel will add again too list but it shouldn't because i already have them in list with same channel info. (new version can't detect channels in the list where was created with old versions)
problem #2 : i can't delete channels from list menu Edit > Delete not work. also cut and undo not work.
problem #3 : downgrading version to 7.06 , will cause progdvb show no channel list , also no plugin !
problem #4 : with 7.06.1 after doing fresh newly scan from second satellite(fist scanned sat is okay) , founded channel not show in the list , need to selected another same name of sat from Channel List Properties windows:
as you can see in this picture , there some duplicate name of sat. some of them have No Source , what dose it mean ? i have three sat added in TV Source and all three of this sat work (have video)
lot of problems currently with channel list :(
PS: there is no 7.06.2 release i cant check.
Regards
#1512
tested .2 release but no change still have all problems i mentioned before.
p update: 7.06.2 after fresh full scan on satellites will add channels too list with no problem. i mean problem #4 fixed thought
#1514
Prog wrote:Do you have old channels directory? (from old ProgDVB without start new versions?)
ps: Old version not support format from new.
yes, my old version channels directory attached. (its from version 7.06 which every thing was okay)
Channels-old-v7.06.rar
old channels directory (v7.06) - without start new versions
(161.01 KiB) Downloaded 253 times
also i attached for you channels directory from new version (v7.06.2) which i freshly scanned today (all channels was deleted from base) fully fresh. now whit ProgDVB v7.06.2 and this new fresh channels i still have problems #1 & #2 & #3
Channels-new-v7.06.2.zip
fresh channels directory from new version (v7.06.2)
(100.87 KiB) Downloaded 310 times
