i am working on progdvg 7.12 it's stable except when i open paid tv channel with any cccam plugin window freeze when change channel and prog will not close except with restart windows..........
any way i installed last progdvb
the above problem still there plus
when i open server module it show me the window normally but then it show error message say
progdvb engine api except in prog dvb engine::module_showdialog
and prog dvb freez and pc need restart
i copied server module from progdvb 7.12 to the last progdvb and when i click server module icon in progdvb it do nothing
i tried ProgDVB7.19.8a.Pro and it is the same
i tried ProgDVB7.15.1a.Pro and it is the same
hope to solve that
#1758Thanks for replayProg wrote:Please send me this plug in after 8 jul
The problem happens with any sharing plugins like
ACamd v0.6.2.0
http://skystar-2.com/plugins-ACamd_v0.6.2.0.rar.html
HADU DVB Plugin Beta v0.1.2.7
http://skystar-2.com/plugins-Hadu_CCCam ... 7.zip.html
I searched the forum and found the problem happens with other people and you suggested change demultiplexor from prog to any thing else but that doesn't solve the problem for me plus it cause sound sync problem plus video aspect ratio problem even when use auto detect at geometrical
after testing newer version i uninstall them and installed vlc player ( i dont know if it have effect to progdvb or not !) i make repair to Microsoft .NET Framework 4 ( since i noticed when install progdvb he make refresh to net frame work filles! ) then reinstall prog dvb 7.12.06 again readjust codec and it works but still some times prog freeze when change the paid channel while using sharing plugins and prog may be close but pc need restart if i still want to play prodvb again because if i traied play progdvb again without restart pc progdvb will not open and will freez during loading
i hope you fix paid channel change problem and also the problem of needing pc restart if progdvb freez if we just can close it and open again without pc restart it will be awesome !
and in new version of progdvb regardless sharing plugins problem the new version of server module in progdvb open with error message and prodvb freeze! (using win xp sp3 ) also it doesnt work if i copied old server module (from progdvb 7.12) to module folder of new progdvb
Thanks in advance
#17596 tuners on and crash.
how do you think to solve this problem ???
i need to have all 8 tuners on.
thank.
thank.
- Logs.rar
- (8.28 KiB) Downloaded 887 times
#1760Deinterlacing fails on channel switch with madVR. It's unusable this way...
So many ignored bugs...
#1761You can try other video renderers. I am not author of madVR and not know about interlace in this renderer.
Also you can try interlace settings of video codec.
#1762It was claimed to be progDVB-s fault because: "does a bad job of re-initing the directshow graph on channel changes"
It's annoying because it only works on startup, but when I switch channels it breaks.
Also, I'm quite reliant on madVRs sharpening filters to get good looking video.
#1763Try change speed mode on first page of settings. Different ways of update of graph.
#1765I am not have idea about "does a bad job of re-initing the directshow graph on channel changes". ProgDVB total destroy old graph and create new. (if you not select fast mode)
#1766Well, all I can do is report stuff here and in the madVR thread. Maybe you could contact the madVR dev to fix this if you can reproduce.
(and other bugs like the HD OSD skin not working with madVR)
#1767Afaik madVR not support API for OSD like Microsoft renderer.
Byt yes, I am interesting in contact with author for more information about interlace problem.
#1769hi, i have the octa-tuner tbs 6209.
when i work with the first 5 tuners, the program run well.
but i have 3 tuners that are stopped.
so, i open the sixt tuner, search channels
and at the end all is ok.
but, when i try to press any channel the program crash.
when it restart, it crash without touch nothing.
solution anti-crash:
i go inside the file ProvidersEngine, located in c:\programdata\progdvb
i check this part:
Count=6
src0=bda.80016499.4:{BDA} TBS 6209 Tuner 0
src1=bda.80016498.4:{BDA} TBS 6209 Tuner 1
src2=bda.8001649B.4:{BDA} TBS 6209 Tuner 2
src3=bda.8001649C.4:{BDA} TBS 6209 Tuner 3
src4=bda.8001649E.4:{BDA} TBS 6209 Tuner 4
src5=bda.80016497.4:{BDA} TBS 6209 Tuner 5
i touch count and i fix it with number 5 (count=5)
i delete the last string (src5=bda.80016497.4:{BDA} TBS 6209 Tuner 5)
save the file and close
when i restart progdvb it run ok, but obviously with 5 tuner like before.
can finally fix the problem for the crashes if i use more tuners ???
i need to have 8 work fine, thank.
i check this part:
Count=6
- Logs.rar
- (2.67 KiB) Downloaded 854 times
#1770This is only part of logs.
But do you can enable more 5 tuners in other software? Looks like driver limit.
Also try change change settings of BDA in ProgDVB. For example disable TIF.
