#181
I have not tried the BDA driver due to I record using this card with TSReader and it does not have support using BDA driver. I do have 100% quality of signal. Is this a driver issue, because I never had an issue with TSReader and this driver.
#182
Sleep mode trouble may depend on hardware and driver, and of course also on the kind of sleep mode. Not all hardware can use all sleep modes S*.
Also refer to the hardware manual and compare with the original application, that came with the hardware.
#183
Every time i launch progdvb it says that Progdvb engine crashed during latest run, and ask if i want to reset program. If i say yes and configure settings again all is well at next programlaunch but after that error message again. if i do not reset program program works ok, but error message on every launch bugs me. :?
Artec T14BR dvb-t usb receiver
Core2duo e6300
Geforce 8600Gt
Windows Vista SP1 32bit
#184
Hm. Do you have admin rights?
#185
Prog wrote:Hm. Do you have admin rights?
yep, and UAC is disabled.
#186
Hallo,
ich have an GENIALTEC and an SkyStarHD DVB-S-card on Windows XP SP2 with AMD dual core 6000+.
I tried ProgDVB with both cards and got the same result.
Channelscanning on Astra 19,2" returns all Channels with a Framerate of 22000. It scans also the Framerate 27500, but found no Channels. So all Channels i want are missing.
This happens so on several computer.
The shiped program for the SkyStarHD works korrekt and returns all Channels. So the Hardware is korrekt installed. For the GENIALTEC-card i have only ProgDVB, so i cant use this card at the moment.
Whats wrong?
Sorry for my bad English, Greeting from Germany
#187
If a device uses BDA drivers instead of cnventional WDM, it requires tuni9ng space registry entries, as reported here many times already --> search function...
The installer of the Geniatech original software (special 3rd party version of ProgDVB) should create that entries.
If you want to use another version of ProgDVB, install that one into a different folder, and in case copy necessary extra files from the original one.
#188
First of all really nice work with version 5.13.9.
I tested the two version and I found only two minor bug.
1) on the 32 and 64 bit when you go onto the channel list and move the mouse wheel you change the volume level instead of moving the channel list up and down. And the opposite happend if you use the mouse wheel onto the volume bar (the channel list moves up and down)
2) On the 64 bit version I can't use my Cam that is a Predator. It is viewed but it doesn't work. The cam work perfectly in the 32 bit version.
In any way really good job Prog. Now I'm not experience the loos of signal (tic tac on audio) that I had on the version 4.
Hoping being helpfull I say you bye.
Opteron 175 @ 2,2 Ghz (on gigabyte nforce3 Ultra), Radeon HD 3850 512 MB, Digitalrise 1041+CI, Th 1.1.0.4 driver, 1 GB RAM, Windows XP Pro
#189
5.14
EVMR doesnt work for me. using graphs and it says something about Pin connectors when i switch channels. after that message its shuts down.
had no problems with it in 5.13.9
VMR/7/9 still work in 5.14
already tried to create new graphs but it still didnt work with EVMR.
tried on vista x32.
#191
cyberlink power dvd
and ac3filter for audio
same problem like warre1 - with workaround
#192
I have the same problem like user warre1 (...crashed during latest run...).
I found, that in the ProgDVB.ini the property ExitCheck (below [Options]) changes from 1 to 0 after leaving the application. Why, I don't know.
My workaround is to configure ProgDVB completely and then to switch the ini-file to read-only. This works fine.
#193
ProgDVB crash if I try to roll upwards and below with the mouse wheel to change the volume.
I use ProgDVB 5.14.03 (X86)
#194
I have today ProgDVB updatet from 4.89 to 4.90.3.
- parallel installed 4.89 and 4.90.3 on 2 different directory's
- same channels and settings for both installations with dscaler codec
- Avermedia BDA Driver for Avermedia M115 DVB-T Card
Problems with 4.90.3 :
- on some channels dropouts in video
- sometimes audio has dropouts after select the channel
- sometimes audio is at startup of the channel ok, but later ProgDVB loses complete audio - I must select the channel again
In 4.89 all is fine...
Windows XP SP2 MCE 2005 Avermedia 115 (BDA)
#195
when closing progdvb, i get everytime a memory leak error! thats pretty annoying
controls dont work very well, UP DOWN LEFT AND RIGHT dont response.
so i cant change channels in fullscreen with "channellist OSD" and then choosing a channel with the arrow keys. in windowsmode the keys work in the channellist.
using 5.14.4 on vista
