#196
Hello. I'm using ProgDVB x64 version 5.14.4. I see in task manager that memory used by progdvb increase 20-30MB everytime i change channel! After 20 channels changed, progdvb use up to 500MB of RAM and the system become unstable!!! I tried with the x86 version and disabling timeshift, but is the same. I'm using Vista Ultimate x64 with the incuded microsoft decoder for audio and video. No plugin installed and tried also with different video render.
Have anyone the same problem? Who can help me?
bug
#197
Hello, I’m found lot of bugs in version 5.14.04
1.) My Debugger means, ProgDVB has Memory leak.
2.) If state windowed, the window cannot move.
3.) Loudspeaker track-bar cannot change when display is selected. (Mouse wheel).
4.) The Window state is not always saved.
5.) Is Window state maximized and change it to windowed, windowed is maximized and the top border is out of screen.
6.) View or not view navigation bar, is not always saved.
!! Please… remove or make definable the popup windows on full or windowed state. Please !!
And lust but not least,
very thanks for this create work… ProgDVB, and sorry for my poor english.
Grüße gispos
#198
when changing a channel, i have to be lucky if the channel works at the first time. if i click on a channel it happens often that at teh first channelstart the sound goes off after 1 sec, 2nd time again...3rd time black screen no sound...and 4th try works finally...thats pretty annoying too :)
#199
thehoff wrote:when changing a channel, i have to be lucky if the channel works at the first time. if i click on a channel it happens often that at teh first channelstart the sound goes off after 1 sec, 2nd time again...3rd time black screen no sound...and 4th try works finally...thats pretty annoying too :)
You can try remove empgpdmx.ax in filters directory.
#200
yeah this seems to work...whats this file anyway?
#202
i, i also tried 4.90.4 and when i change to EVR it gives me an erro: this render not supported. change to VMR.
ProgDVB5.14.5
#203
Teletext doesn't work in this version with DVBT card.
Since 5.14.4 some typing errors:
#204
5.14.5
At first - thanks for repairing sound problem :D In this version I cant get to work subtitles (txt nor pid type). Tryied many channels, every video renderer, but no luck. In older version was no problem.
#205
Yany wrote:5.14.5
same subtitle problems here too.
#206
Yany wrote:5.14.5
The version 5.14.05 does not scan pid for txt or bitmap subtitles and
does not save this pid after a manual setting
#207
DVB & txt Subtitle not work on 4.90.5 version...
#208
What channel have problem with subtitle?
#209
Digi Film 1,2 12607 H 27500 from sat Intel 10.02 (1" V)
Viasat Explorer 12643 H 27500 from sat Intel 10.02 (1" V)
...subtitle not work
Re: bug
#210
gispos wrote:Hello, I’m found lot of bugs in version 5.14.04
Grüße gispos
i have same issue like in point: 2,3,4,5,6 ;)) 5.14.05 Pro with licence
Regards
