Re: restarting after crash repeatedly on startup
#32
I am also getting this very same problem with all versions of ProgDVB and ProgTV.
I have tried un-installing and re-installing but this did not work.
I have just had some windows 10 updates I suspect it has something to do with that.
I cannot be sure though the same programs are running ok on a laptop that I have but no longer work on my desktop.
Any ideas anyone.
#35
Seems that Microsoft smashed some codec :
"After investigating, this is the filter responsible:
Microsoft DTV-DVD Video Decoder
C:\Windows\SysWOW64\msmpeg2vdec.dll
{212690FB-83E5-4526-8FD7-74478B7939CD}"
People have problems with .ts files and some with mp4 files.
For Win10 deinstalling the latest update KB 4013429 helps.
I use shutup10 for blocking the update to reinstall.
#36
tini wrote:Seems that Microsoft smashed some codec :
This did resolve the problem I have just tried it and my registered ProgDVB started up without any problem. I will most likely get a re-install of KB 4013429
#37
Oh dear Windows has just re-installed KB 4013429 again and the same problem has re-appeared restart and crash restart and crash over and over again hope the maker of the program of ProgDVB and ProgTV can fix this as its a windows update problem and not an error in the program. A lot of people that have ProgDVB aren't going to be able to keep uninstalling KB 4013429 as that update coverers so many issues.
#38
As i wrote above, i use "shutup10" ( https://www.oo-software.com/en/shutup10 ).
A little freeware tool, you dont have to install it , just open it and choose the things you want that win10 dont do again, close and restart, finished. So you can disable also the update function, i reable it for a few hour every "Microsoft Patchday" for staying updated.
Available in English, German, French, Italian and Russian :P
#39
Prog wrote:Can you start ProgDVB without channel and select other video renderer? Or and video codec for mpeg2?
I have reset all settings.
First start crash, the second start the prog starts, but when i select a channel, he crashes anyway.
Do you have any idea? Or would you like per teamviewer on my pc?
Oh I see the KB Encoder Problem, would you like fix the Problem, or sold i go back to the old Encoder?
Best Regards from Rheinland Pfalz
Georg
#43
I'm having the same crash problems sinds 16-03, as voiced here.
Changed to different versions of ProgDVB, changed the codecs to LAVFilters-0.69.1 and disabled “use Microsoft WMV9 DMO Decoder."
Ended up with ProgDVB 7.17.9b wich runs OK now apart from crash problems on 5 channels. Still crashes on Dutch Public TV (HD, 3 channels) and German ARD and ZDF. All other channels working fine.
I use Windows 10 pro 64 and a Hauppauge WinTV-1975 PVR Model 16000 Hybrid DVB-C.
Any ideas solving this problem?
Thank You
logs.7z
(12.79 KiB) Downloaded 313 times
