Please try SAT>IP in last version
http://www.progdvb.com/download_progdvb_prerelease.html
Re: SAT>IP Protocol support
#348Hi!
It seems that it will not work with minisatip server. It always stuck at "preparing"
Possible listing on
http://www.satip.info/products/Software ?
I see that user agent is VLC.
- Api2Device::SetChannel - None
- skip old generation traffic!
- Api2Device::SetChannel result OKhttp://www.satip.info/products/Software ?
#350Yes. It is important to say that channel will play in VLC even if it is restreamed from Prog Media server(m3u)
- * s:100 q:100 tr=278992 (0) Preparing
- * s:100 q:100 tr=223720 (0) Preparing
- * s:100 q:100 tr=222404 (0) Preparing
- * s:100 q:100 tr=225036 (0) Preparing
- * s:100 q:100 tr=226352 (0) Preparing
- * s:100 q:100 tr=221088 (0) Preparing
