I have found an issue with EPG and am not sure if it applies only to my local area/channels or is more widespread.
link 1) http://www.activesoft.com.au/misc/1.jpg
Here you can clearly see selected the show "Real Estate Lifestyle" and the description is shown below. This is good.
link 2) http://www.activesoft.com.au/misc/2.jpg
Here it gets interesting. I have selected "Before the game" but the only description is "[Program Info Ten]". Any program selected from channel "Ten digital" or channel "ONE HD" (run by same company) always results in the same "[Program Info Ten]".
Now I know for a fact that there should be more description. From windows media center:
link 3) http://www.activesoft.com.au/misc/3.jpg
You can see the same program "before the game" has more description plus appended the text "[Program Info Ten]". However as can be see in link 2, ProgDVB only has the last bit and doesn't have the whole description.
Another issue is that, you can see in link 2 that even though i have clicked "before the game", it is not highlighted as it should be. This is true for any program I click on from channel "Ten digital" or channel "ONE HD", they do not highlight. This doesn't seem to cause functional issues but is a bit weird. Could this be related to the above issue?
Thanks,
Matt
#467First let me thank for this great peace of software.
Let me ask 2 questions:
- is it right, that the build-in scheduler
"use ProgDVB-service for recording without start of ui"
does not / can not wakeup computer from standby (would be nice anyway)?
Which leads me to the second question:
using the windows-scheduler "wakeup - record - standby" is working but progdvb freezes when starting. Why? I use a netbook MSI 100 and when ProgDVB wakes up my netbook from standby screen remains totally dark, maybe this could have something to do with progdvb freezing?
Thanks anyway,
Olnima
P.S.: Fiddling around a bit and yes, it seems that freezing progdvb comes from the not-schwitched-on display which is ok for me (don't want to be woken up in the middle of the night when capturing starts).
When I move the mouse in the moment when netbook wakes up screen powers up and everything is fine. Maybe there is a way that progdvb does not freeze when starting without powering on the screen.
Or maybe have a third option like "use windows scheduler for recording but without start of ProgDVB-UI".
Thanks anyway,
Olnima
#468Yes, current version of my scheduler service not can start PC. I do that in future.
#469ok, would be nice. thanks for replying.
Olnima
Olnima
#470hi
im having a very anoing problem with progdvb and hadu and when ever i minimize progdvb while using hadu to whatch channels and no mater what chanel im whatching and what video or audoi or renderer i use progdvb sudenly crashes and exits . and i dont have this problem with acamd . but hadu is very faster and more responsible to ser... .im facing this prob sins i gues Win vista and after that Win seven i just dont remember what version this thing started whith. enyway i realy be thank full if u som how fix this bug or what ever it is.
thx
thx
#471At first try remove all plugins and disable modules.
#472hi prog and thx for replay .
ok i did disable all modules and plugins . and i started watching a regular channel wihch does'nt need eny plug to whatch and then i minimized and no crash or exits . but like i metioned this crash hapens when i whatch encripted channels using hadu . so i removed all plugins and just put hadu.dll and hadu.ini and minimized progdvb while encripted channel is on and hear we go again progdvb crashes . i tryed again and i started the progdvb again but this time removed all plugins and just puted acamd plugin . and minimized on same channel or ather encripted channels and again did minimized progdvb but this time prog wase ok and no crash. i guess there is some kind of incompatibility with hadu or prog in my situation. i dont know.
what do u think i should do?
thx.
thx.
#473hi
i just got another error and crash with epg and to tell the truth it not that new error and it keeps coming randomly and unexpectedly an hear is the ditails.
thx
System.InvalidCastException: Unable to cast object of type '.' to type '.'.
at ..()
at ProgDvbNet.EpgChannelListHelper.CreateNewList(Object param)
at ProgDvbNet.EpgList.()
at ProgDvbNet.EpgList.(Object , EventArgs )
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
ProgDvbNet
Assembly Version: 6.45.3.0
Win32 Version: 6.45.3
CodeBase: file:///R:/ProgDVB%206.45.3/ProgDvbNet.exe
EngineApiWrapper
Assembly Version: 1.4.2.0
Win32 Version:
CodeBase: file:///R:/ProgDVB%206.45.3/EngineApiWrapper.DLL
msvcm90
Assembly Version: 9.0.30729.4926
Win32 Version: 9.00.30729.4926
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_508ed732bcbc0e5a/msvcm90.dll
System
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///R:/ProgDVB%206.45.3/ProgDvbNet.bc.DLL
IPDev.Skins
Assembly Version: 1.3.21.0
Win32 Version: 1.3.21.0
CodeBase: file:///R:/ProgDVB%206.45.3/IPDev.Skins.DLL
ProgDvbNet.CD
Assembly Version: 1.0.1.1
Win32 Version: 1.0.1.1
CodeBase: file:///R:/ProgDVB%206.45.3/ProgDvbNet.CD.DLL
Accessibility
System.Design
System.Xml
System.Drawing.Design
ProgDvbNet.Win
Assembly Version: 1.0.1.0
Win32 Version:
CodeBase: file:///R:/ProgDVB%206.45.3/ProgDvbNet.Win.DLL
enabled.
For example:
<configuration>
</configuration>
thx
at ..()
mscorlib
ProgDvbNet
EngineApiWrapper
Win32 Version:
msvcm90
System
System.Drawing
ProgDvbNet.bc
IPDev.Skins
ProgDvbNet.CD
Accessibility
System.Design
System.Xml
ProgDvbNet.Win
Win32 Version:
enabled.
For example:
<configuration>
</configuration>
#475thanks for replay again
nothing but clicking the EPG on progdvb whith left moust boutton
thx
thx
#476Please send me files from channels directory and epg.dat
#477lastest progdvb 6.45.4 kword USB DVB-S TVBox (KW-UB365-S) BDA not supported !!
Now is not work with lastest version ):
#478Do you have problem with old versions?
Please mail me direct. I have some questions.
#479Hi Prog
I have a problem with scheduler recording.
I scheduled recording one channel every day for about 5 or 6 hour, but more times when i come back see Progdvb just record 30 min or 1 hour or.... . I do some test and i think every time my signal for just seconds is poor recording is stoped automatic. I test it when i stand for some second in front of my dish and then progdvb crashed or recording is stoped automatic.
I'm using latest progdvb version
SkyStar HD2
Windows 7
SkyStar HD2
Windows 7
#480With the latest versions of ProgDVB 6.46.2/3 i notice some (english) information is missing in the audio recording setting window:
ProgDVB 6.46.3 audio record settings:
