Yes free channel, BDA Device, channel type is SD - BBC News on 28.2E (in the screenshot)
But I tested several free channels on several satellites and the result is the same - black screen
#498I think exactly here lies the problem... program does not account for any signal, so there is no way to scan, see signal indicators that are empty.
#5016.48pro on windows 7 x86
prog media server module does not load.
Other modules such as internet gate server appears in list and works, but media server does not.
Its checked on during install, and new version also exists in modules folder (01-10-2010 10:08 978kb).
#502Please update module if you use Prog Media Server Pro.
#503I made a little mistake in my post, its not "progdvb media server" , its the program progdvb pro ,and its "media server" module that does not work.
As i wrote previous, i checked that the modulefiles was actually updated, and they were correctly updated to the ones in 6.48,but does not work. If i install progdvb pro 6.47.2 on both parts, it works again.
#504ProgDVB 6.48.01
Prog Media Server does not load
#505There is one bug that I found in ProgDVB regardless of version.
Run any television then switch to another sound and began to haggle.
I try to change the audio codec and everything is fine, but when I change again television sound again began to haggle.
These are SD TV with mpeg sound like this:
I tried a variety of audio codecs, but do not fix this problem.
And when watching music television is very annoying sound to interrupt.
In the options "use audio processor" I've turned off
#506Try different renderer settings.
I don't have any such trouble, when using my Nexus in software mode.
Just tried a few older versions of ProgDVB, set all codecs to blank, to force use of system wide available ones.
Results are:
Cyberlink Video/SP Decoder (PDVD8), which came with my DVD writer.
Microsoft MPEG 1 Audiodecoder Version 2.0
Default DirectSound Device
VMR9
Of course results may depend on the computer used pretty much.
And even on the tuner, as for example the Nexus still does the stream filtering in hardware, even in software mode.
Results are:
VMR9
#507Error related to channel list in the last version (6.48.2).
I opened the dialog to add a new channel list. Then I closed the window clicking on "Cancel". Exception dialog appeared with the following message.
There were two choices: Continue or Quit.
I chose Continue. Program continued to work but there was an empty box in place of channel list.
After restart of the program exception appears again.
at IPDev.Skins.SkinTabControl. (PaintEventArgs )
at IPDev.Skins.SkinTabControl.OnPaint(PaintEventArgs pe)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
at System.Windows.Forms.Control.WmPaint(Message& m)
at System.Windows.Forms.TabControl.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3615 (GDR.050727-3600)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ProgDvbNet
Assembly Version: 6.48.2.0
Win32 Version: 6.48.2
EngineApiWrapper
Assembly Version: 1.4.2.0
Win32 Version:
msvcm90
Assembly Version: 9.0.21022.8
Win32 Version: 9.00.21022.8
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_d08d0375/msvcm90.dll
System
Win32 Version: 2.0.50727.3614 (GDR.050727-3600)
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
IPDev.Skins
Assembly Version: 1.3.21.0
Win32 Version: 1.3.21.0
ProgDvbNet.CD
Assembly Version: 1.0.1.1
Win32 Version: 1.0.1.1
CodeBase: file:///C:/Program%20Files/ProgDVB/ProgDvbNet.CD.DLL
Accessibility
System.Design
System.Xml
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
System.Drawing.Design
ProgDvbNet.Win
Assembly Version: 1.0.1.0
Win32 Version:
enabled.
For example:
<configuration>
</configuration>
#508I think I found a bug,
I use an Azurewave SP400 DVB-S2 card together with a 2 port DiSEqC switch (Astra 19.2 & 23.5) and my operating system is Windows XP SP3.
Since version ProgDVB6.46.6Std upwards I experience difficulties using the 2-port DiSEqC option (22 Khz, switch 2 ports) I do not get a signal at all.
However if I use the 4-port DiSEqC option (DiSEqC 1.0 4 ports) and only use the first two ports (for 19.2 and 23.5) I do get a picture! But I do not own a 4 port DiSEqC switch, I have a 2 port DiSEqC switch. (using ProgDVB6.48.3Std)
- DiSEqC 1.0 4 ports
- DiSEqC.PNG (10.92 KiB) Viewed 8064 times
#509I have noticed a similar problem and I, I use 10-port switch DiSEqC when changing from one TV to another happens to me the signal to disappear and have to wait 10 seconds to reappear signal which leaves the picture. If it happens rarely had a problem but as a person shifts 20 television channels and 15 times he had to wait for 10 seconds per channel this is a problem. I tested with another program dvb-dream 1.5e and I can say that there no such problems. My thought is such that I bought this program and this program I like, but another problem is not that many bugs which still is quite true, the problem is that many come out new versions and bugs remain. That we do not like and hopefully these things are fixed gradually. We had a chance to test other programs like dvb-viewer, smart-dvb and dvb-dream but when we choose prog-dvb want to use it fully and it can normally without any problems to watch television with her. Or at least have a version that is stable. I do not know whether the developer should focus on the releases or post it to a new version but stable with no bugs.puch-maxi wrote:I think I found a bug,
Sorry if you do not understand something, I use google translator.
Thanks
#5102 puch-maxi: Do you really like use 22khz? Becuase this type of diseq not compatible with universal LNB.
2 2HD: What DVB device? 10 seconds is very long. Should be 1-2 seconds.
