ProgDVB64 and ProgDVB32 crash on Vista 64bit and Win7 64bit
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
Re: ProgDVB64 and ProgDVB32 crash on Vista 64bit and Win7 64
#61 by Prog
one more idea. Do you have normal OS? For example ProgDVB can not start if you cut MS scheduler from win.
  • Fri Jan 20, 2012 7:05 pm
michael46
michael46
Sat Jul 18, 2009 8:58 pm
#62 by michael46
I have no special configuration, MS task scheduler is not cut.
Some news:
Checking all dlls of the free x64-version 6.82 showed two issues:
1. The dll msvcr90.dll was missing.
2. The Ionic.Zip.Reduced.dll is a x86-version.
Logs are attached.
Logsx64.zip
(1.11 KiB) Downloaded 285 times
  • Sat Jan 21, 2012 11:54 am
#63 by Prog
This file in Microsoft.VC90.CRT... Try copy to root of ProgDVB.
  • Sun Jan 22, 2012 5:32 am
michael46
michael46
#64 by michael46
I did as you suggested and the complaint of the missing msvcr90.dll is gone. But what about the x86dll?
  • Sun Jan 22, 2012 11:09 am
#65 by Prog
What about x86?
  • Mon Jan 23, 2012 7:56 am
michael46
michael46
#66 by michael46
michael46 wrote:...
  • Mon Jan 23, 2012 10:54 am
#67 by Prog
For .net assembly's OS not important. Same file for x64 and x32.
  • Mon Jan 23, 2012 5:21 pm
michael46
michael46
#68 by michael46
Do you suggest any other tests?
  • Tue Jan 24, 2012 10:51 am
#69 by Prog
Also you can edit ProgDVB.ini and add
[Debug]
RegisterForRestart=0
and send send me error text from OS.
  • Tue Jan 24, 2012 2:13 pm
michael46
michael46
#70 by michael46
Afterwards the same error message is given as sent before, no entry in the event list.
  • Tue Jan 24, 2012 3:40 pm
michael46
michael46
#71 by michael46
How can the problem be solved?
  • Sat Jan 28, 2012 5:59 pm
#72 by Prog
michael46 wrote:Afterwards the same error message is given as sent before, no entry in the event list.
What is event list? Scheduler?
  • Sun Jan 29, 2012 5:35 am
michael46
michael46
#73 by michael46
The event list is on of the lists of the Win7 event viewer. There are no ProgDVB entries in the application or system lists.
Which error text of the OS do you expect?
  • Sun Jan 29, 2012 12:27 pm
michael46
michael46
#74 by michael46
Please answer my question!
  • Thu Feb 02, 2012 12:01 pm
#75 by Prog
I am not have idea about this. ProgDVB not found some system component (not driver!) on your PC.
  • Thu Feb 02, 2012 4:34 pm
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
Re: What is the way to activa…
I am not remember what driver type use 3650. Do you use select {bda} xxxxx in TV sources of ProgDVB? 1. Check propertie
Prog, Mon Mar 30, 2026 12:34 pm
ProgDVB must support this CI without plugins. Do you use BDA or WDM driver? Try WDM at first. WDM? Try it. How do
nasser, Sun Mar 29, 2026 7:45 pm
Prog, Sun Mar 29, 2026 6:48 am
Try x32 version of ProgDVB. Check Settings->CI Do you mean this version? ProgDVB + ProgTV x32 for x32 or x64 Windo
nasser, Sat Mar 28, 2026 1:39 pm
  • It is currently Wed Apr 01, 2026 11:49 am
