ok thanx i have found it and i have remove start of progdvb...
i have see in MS scheduler many schedule removed from progdvb schedule..why they remain old recordings?
#812Some bug in ProgDVB or seсurety limit of OS.
#813Hey,
i have a Skystar 2 and have the following problem:
if i start progdvb x64 (newest version) the first time, everything works.
if i start progdvb x64 (newest version) second time, i got only artefacts. i don't found a fix for that damn bug
Operating System: Windows 7 64 Bit Ultimate.
Only a restart works.
#815don't work, same problem. any other ideas?
#816Please provide more details, like
- level and quality, with and without that error
- codec, renderer
- what kind of artefacts, exactly
- audio still OK or also effected (and if, how exactly)
- what driver used
- codec, renderer
- what driver used
#817the bug i reported in the last build seems to be fixed now in fact it seemsa lot mroe stable and better even in memory cpu usage which is good for me since i havea fault on the motherbaord causing me toi lose most of my meory
#818Hi!
After installing the latest version of ProgDvB Pro 6.65 - I get following error:
"Error at ArcSoft demux creation! Please select other demultiplexor in Settings-> Options"
Tried on Win 7 32bit
Arcsoft demultiplexor works fine for me in 6.63.10
#819Working fine or not show error?
Try open File->properties->Demux
Also you must use ProgDVB x32 for x32 ardsoft demux.
#820Hey,
if i start progdvb x64 (newest version) second time, i got only artefacts. i don't found a fix for that damn bug .
Okay, here are the informations.Please provide more details, like
- codec, renderer
- what driver used
The Audio is on first start completly okay.
On Second (buggy) start, no sound is available.
If you need more informations, please respons
Kindly Regards
MaCXyLo
- progdvbbugreport.zip
- (1.35 MiB) Downloaded 474 times
#821Ok, that's tons of system specific data to look through...
But it does not contain anything on the tuning state.
BTW, why are you running the desktop at 1920x1200?
That's not the native resolution of your LG screen, should better be 1920x1080.
And you are almost guaranteed, to see egg heads on some applications, that may still be expecting square pixels...
However, in case of error, do your quality readings drop?
If yes, you are probably suffering from some tuner initiating / continuity / timing issues. For example, try to find out, if your LNB's LOF (used) is a bit off-centre, by this requiring the LOF value in ProgDVB to be corrected 1 or 2 MHz up or down. Detune manually to find the centre of the hold range. If that's not exactly at the nominal transponder frequency, correct the LOF used into the opposite direction.
If not, it's supposed to be some kind of streaming / networking related trouble, like if your firewall possibly interfered.
Oh, and better don't let a timeshift file reside on your SSD. Have timeshift deactivated or in RAM (or on the second drive, after increasing free disk space there).
#822hi prog
there is video and audio sync bug with progdvb demux with moviemax star hd in all must all versions sinc 6.5x
and the other bug which is allmost fine in 6.51.7 but in later versions is realy anoying and it is when im recording a channel and for some reason if the channel losse signal for a millisecond the audio video sync will lost and the oly way to fix is to stop recording and refresh channel .
i hope it will be fix in later versions
thx
and sorry for my bad english.
thx
#823You can try select other demux in ProgDVB.
#824hi
i did select the other demuxes but the problem is with elecard demux i dont have audio on some chenels or i lose sync after a few min i lose audio sync or with cyberlinc and microsoft demux i dont have video picture on some other channels .
and with arcsoft the results is just like elecard .
so far the prog demux is the best for me but the issue i posted before still exists.
thx
thx
