#886
Ok. Found out what really happened (and yes, it is 32bit):
I use C:\DVB\ProgDVB for installation. Usually the update installs by default in the same location, so i don't check the path :roll:
This one installed default in C:\Program Files\ProgDVB and i didn't noticed. Since the shortcut was updated, it worked, but it was in another folder and thus without registration key, disecq setup and all the other things.
Reinstalled again over the old path and everything is working ok.
So the only issue is: Update does not default to the existing ProgDVB folder...
ProgDVB Pro, registered, of course.
#887
i have some problems with latest versions, some errors appear when i close progdvb.
http://imageshack.us/f/403/error2g.jpg/
http://imageshack.us/f/444/error1y.jpg/
Second, some errors appear when i use mosaic:
http://imageshack.us/f/834/error3s.jpg/
Third, pip not working, on pip panel i see only 1 channel.
Example, i watch channel A, i click on PIP, i see only channel A .
I could never use PIP in progdvb, in any version.
http://imageshack.us/f/88/error4t.jpg/
Four, in quality signal at "Q" i have signal loss. Sometimes is say 100%, but 1-3% are lost.
At "L" i have 100%.
Sometimes is say 70%, when image freeze.
http://imageshack.us/f/442/error5.jpg/
What does mean? It mean i have bad signal?
Attach is my logs.
I have 2 logs, first is when osd errors appear, second log it's from signal dropped to 70% and my recording was trashed.
here is an rec when signal dropped to 70%:
http://refile.net/f/?cuN
mirror: https://rapidshare.com/files/3865954732 ... 3.09.51.ts
(804.67 KiB) Downloaded 470 times
(759.57 KiB) Downloaded 487 times
#888
reeven wrote:i have some problems with latest versions, some errors appear when i close progdvb.
At "L" i have 100%.
Attach is my logs.
same problem on mosaic....
#890
Pls use spoiler or zip
#891
this bug:
i notice some problems, when i startup up progdvb for the first time in a day, progdvb freeze, image continue to run, sound as well, but circle from mouse appear on progdvb image, and i am force to close progdvb.
still present in latest 6.73.04
pip still not working
mozaic as well.
#896
yesterday was the first day when i use progdvb Client on laptop.
On an dual core amd 2ghz, i have 70-100% processor usage on laptop when watching live-tv on client pc.( on HD channels), i use also high performance energy mod.
With this laptop also, using dvbviewer client, i have 2-15% processor usage on SD or HD channels.
When using DVBLink + mediacenter on laptop( stream over network) i have 2-15% processor usage on sd or hd.
Also, on client, i see :
1.signal is 60-80%, but on server is 100%. ( i use wireless 54mbs)
2. if i zapp on 3 channels, i have 3 fddshow audio icons in taskbar, if i zapp on 100 channels, i have 100 fddshow audio icons in taskbar.
And, if i close video window on progdvb server, live-tv stop working on client.
I must leave open progdvb with image on server,
