#901
Having Error message when i want update list (Audio (or) subtitle) in latest version. message is:
"ProgDVB Engine API Except in ProgDvbEngine::AV_SetChannelSubStream"
picture: http://up5.iranblog.com/images/xl9nvwr4wcqqx4vgce0.jpg
also mosaic problem (error) still exist.
and when want to exit progdvb it take 15 second!!! (its not so important :D)
Log file attached:
Logs.zip
(663.41 KiB) Downloaded 525 times
#903
Prog wrote:Arcsoft not support this function. Please use Prog Demux.
change demultiplexor to Prog but still have that error.
logs after change demux:
Logs.zip
(341.08 KiB) Downloaded 363 times
#905
Prog wrote:Hm. try audio codecs also. Is it same type of audio stream?
:cry: changing audio codecs (with progdemux) still not work and have error. (with ffdshow automatic gain control is disable)
what do you mean from : Is it same type of audio stream?
#907
Prog wrote:For example change from mpeg audio to mpeg, more simple then mpeg to ac3.
cant solve that error. sadly find new problem in :
File(menu) > input traffic information > Filter Manager (tab)
when i click on filter manager progdvb crash occur (see picture) but progdvb engine still open and after restarting progdvb automatically , have timeshift buffer is overflowed and i have to close progdvbengine from task manager.
its so complicated! Pictures:
http://up.vatandownload.com/images/ewmu ... x0f2jo.jpg
http://up.vatandownload.com/images/1ia8 ... x5el1v.jpg
http://up.vatandownload.com/images/5qcc ... 35m2f7.jpg
have this problems on latest pre-release 6.74.2 pro 32bit
Logs + report.zip
(218.24 KiB) Downloaded 369 times
#908
when Audio Render Properties window is open and at the same time change channel , error happend.
picture:
http://up.vatandownload.com/images/wheu ... y7ql65.jpg
http://up.vatandownload.com/images/xd3h ... umaqi8.jpg
still Filter Manager make crash progdvb for me.
still have error with update audio and subtitle ( "ProgDVB Engine API Except in ProgDvbEngine::AV_SetChannelSubStream" )
still mosaic And PIP not work ......
with ProgDVB6.74.4Pro per-release.
#910
Prog wrote:1. I know. But not have idea how fix that. ProgDVB try close dialog if possible.
2. Same problem with today prerelease?
3. I check that in future.
4. What problem with mosaic/PIP?
Yeap same problem on 6.74.4 Pre-release.(all of them)
PIP: in pip when i select second channel both of them stop and have no picture.
mosaic: http://up.vatandownload.com/images/4gp5 ... ge93sc.jpg
http://up.vatandownload.com/images/k7ti ... t5vg1n.jpg
:-?? :shock:
#911
yes! PIP work now (V6.80) only when timeshift mode is set to : "All channels from transponder store in buffer" OR "Not Close Device and buffer of old channel when open new"
thanks.
have above problem (tell you before)
:wink:
#912
i did not know that for PIP and mozaic to work, i need to :
in timeshift mode is set to : "All channels from transponder store in buffer" OR "Not Close Device and buffer of old channel when open new"
Now pip and mosaic is working in v6.73,v6.74, and v6.80.
#913
ProgDVB in PIP mode , plugins (Hadu) not work and cant decode scrambled channels.
in the first tab (first channel) i can see plugins menu but DCW not work and in the second (Channel Opened by PIP) there is nothing in the plugins menu.
whether or no When ProgDVB is in the PIP mode can not use CCCAM with plugins.
tnx :roll:
#915
reeven wrote:i did not know that for PIP and mozaic to work, i need to :
I am not have idea. Please select "one channel in TS" mode and send me log of bad mosaic and PIP operation.
