#947
Prog wrote:Is it working in previous version? 6.83 must working without winlirc.
work perfect with 6.82. but cant use control in 6.83 with or with out winlirc.
#948
progdvb 6.83.0a , skystar remote control works Only with WinLIRC module.
#950
Prog wrote:Try update this file.
http://test.progdvb.com/28/SkyStar2.Device.zip
after update this file , progdvb 6.83.0a remote control not work even with WinLIRC (witch work with old SkyStar2.Device).WTF :-? tried to reinstall 6.83.0a but still not work :((
what was the problem about the remote control? every thing work perfect before why you modifies that?
#953
Prog wrote:What last good version of ProgDVB?
after update that file NONE of version work. but 6.83.0a work with winlirc before update SkyStar.Device.can you give me the old skystar2.device please?
#954
ProgDVB6.83.1Pro , remote control still not working.
ps : my remote control work perfectly with KMPlayer plus WinLIRC.
#956
Prog wrote:But, do you receive keys in ProgDVB without Winlirc?
nope.
can you give me the old skystar2.device please? think that is the problem
#958
Prog wrote:You can take it from last good version. Please report me after that.
sorry every thing is good with SkyStar2.Device
The "Proxifier" make some problem with WinLIRC ( it send local request to the server ).
only work with WinLIRC
#960
Prog wrote:And so, no any problem with Winlirc in last ProgDVB?
ps: Of course any firewall can block winlirc.
ProgDVB 6.83.1a work OK with WinLIRC.
Sorry for my mistake. :oops:
but i think you said it should work even with out WinLIRC ..... :?:
