#992I think this is antivirus problem. You can add ProgDVB to exclude list.
#993I also thing this is the antivirus problem because I get same error on regional site who is clean, I thing so.
I disable real-time protection and download progDVB, after that I scan progdvb.exe and antivirus not found any risk, now installed and i use latest version.
#994PROBLEM WITH CHANNEL SELECTION IN FULLSCREEN (REMOTE OR KEYBOARD)
1. Enter to LIST1 and select a channel.
2. Press <Enter> and then go to LIST2 and select a new channel.
3. Thats it... ProgDVB no longer listens to IR remote or pressing <Enter> on keyboard.
The temporary workaround is to press with the mouse on screen.
#995Hi,
I have a problem with the newest builds of ProgDVB regarding my country HD streams.
The problems have occurred since the build 6.84.2 and I can't find any solution to get the audio stream working now.
My HD streams are E-AC3 (Dolby Digital Plus) are now detected as AAC streams instead of AC-3, causing an incorrect demultiplexing process. I have no sound no matter the demultiplexer or audio codecs picked in the choices panels.
It works perfectly in the 6.84.1 version with FFDSHOW audio codec: the streams are recognized as AC-3 and the FFSHOW trayicon appears.
I tried 6.84.2 and 6.84.3 and same issue.
I think there was a change in the PAT/PMT program information detection and ProgDVB can't deal with the emulation of audio headers. The detected type is not the one in the PAT/PMT information
#996Same after rescan of channels?
Please record me 3-4 minutes of stream in Service->Pid recoder.
#997hi,
my PCSAT is a TBS6925 and i have downloaded the latest trial version(6.84.2) for test it. I think there is a problem with proglauncher.exe as i cant use another program with my card when it start up with XP although you close it directly with the task manager. And if you dont boot with this proglauncher service then you cant use progdvb!!
regards!!
regards!!
#998Prog wrote:Same after rescan of channels?
Same thing after rescan. I recorded 3min of the stream and I'm uploading it to a webserver. Will pm you the download link when ready (200MB)
#999H3lli0n: Thanks! Downloaded. But I am not can promise fix that before end of this month. Very busy
te11120: Try start with admin rights.
#1000Im using XP 32 bits with administrator user. If i run progdvb when proglauncher is disabled on boot i can search for channels but i cant watch any channel and the tunner bar show 0% of signal. If i boot xp with proglauncher then there is no problem.
#1001Mark admin rights in ProgDVB shortcut properties.
#1002I don't know if it was meant to be but my issue isn't fixed in the **.5 build.
Is there a changelog page ?
#1003In the latest version the hotkeys don't work properly.
F.e. Ctrl+F
It only works if I have selected "Search" from the menu with the mouse
							F.e. Ctrl+F
#1004Ops. That is problem... I try fix that in next version.
#1005in the new version numbering of channels doesn't work. by pressing of cleaning of numbering there is a falling.
