Hi
I've used progdvb together with a technisat combo box (and windos 10) without any problems. Since yesterday I cannot start the program anymore.
I've deistalled it several times I have installed different versions and so on. Always the same:
a) the start pic is visible but disappears after a few seconds.
b) I get the message that an error has occured and the program restarts - that could go on like this for hours.
What can I do?
vanbrel
Re: no start of program anymore
#2Please try "g" prerelease and report me result.
http://www.progdvb.com/download_progdvb_prerelease.html
#3Same here.
Yesterday, progdvb worked properly, today it chrashes after startup. I did not change any progdvb settings. But: there was a windows update.
Tried so far:
Restart program normal, with last working settings
start program as admin
updated program
reinstalled program
installed this g prerelease.
I am using Win10 64bit.
EDIT
Found this problem in bug feeback. Reading first, posting second
. My bad. I try the suggestions there.
Tried so far:
updated program
reinstalled program
EDIT
