Is it possible to install some codec in the free version of the program? I can not watch my channels in Full HD because no H.265 codec is present in the program.
For the TV box the progtv app runs perfectly on full HD channels just like the VODs.
Re: Codec H.265
#2Do you mean Android or Windows? In windows you must check version of driver. For ProgDVB x64 need x64 codec.
Re: Codec H.265
#3I am using windows 10 x64 as well as the x64 prog.
Where can I download or even enable the h265 codec?
Re: Codec H.265
#4You can try LAV and afaik Win10 include h265 codecs.
Also more codecs for x32 version of app.
