    • Unanswered topics
    • Active topics
no audio
miguelm
miguelm
Sun Dec 10, 2017 9:23 am
no audio
#1 by miguelm
Hi,
some channels I have no audio, what can I check?
in one of the channels, I have the following letters: 1920x1088 h264 - stereo mpg
  • Mon May 28, 2018 5:08 pm
Re: no audio
Try other playback mode. Some devices not support mpg audio in OpenMAX mode.
  • Mon May 28, 2018 5:11 pm
miguelm
miguelm
Re: no audio
#3 by miguelm
Hi,
yes I have try all of them available, one by one, is there any other option?
  • Mon May 28, 2018 5:30 pm
Re: no audio
#4 by Prog
Try change in menu of channel
  • Mon May 28, 2018 5:47 pm
miguelm
miguelm
Re: no audio
#5 by miguelm
Hi,
I have tried also in the menu channel, nothing works, I think I tried with all the possible options
it works fine with http://siptv.eu so its probably something on the ProgTV no?
can you advise? anything else I can do?
  • Thu May 31, 2018 9:04 pm
Re: no audio
#6 by Prog
Try FFmpeg or MediaCodec modes. Must working in any case.
  • Mon Jun 04, 2018 9:22 am
Return to “ProgTV Android”
Re: weird issue with subtitles
You can try prerelease but still not best way https://www.progdvb.com/download_progdvb_prerelease.html thanks, i tr
xtc82, Mon Jan 05, 2026 7:40 pm
Prog, Mon Jan 05, 2026 5:53 pm
btw, can you record me long sample with subtitles? 4-5 minutes. Service->TS recorder->All TS of course... thank you
xtc82, Sun Jan 04, 2026 10:37 pm
Prog, Sun Jan 04, 2026 8:20 am
  • It is currently Fri Jan 09, 2026 10:57 am
