Hello!
I m using in my Flat a DVB-C receiver (technotrend) for my TV, connected it an he found a lot of channels (works well). The signal comes form a "headstation" (wich is connected to a satelite receiver i think).
Now i bought a Technistar (cablestar 2 TV) an used prog DVB, but i cant find any channels, with the software from technistar its the same problem.
Seach runs, takes a lot of time and at the end no channels found... but vor example on my TV receiver i can see that on (322000, 64 quam, 6875) is a channel...
would be really glad if somebody has any ideas!
Greetz Tim
Try to scan a transponder manually, using the same parameters that are working on your TV receiver.
Perhaps you will have to create your own transponder list for full scanning, as most probably the values are non standard in your situation.
Editor rulez...
Editor rulez...
