    • Unanswered topics
    • Active topics
Why not open the FLV extensions.
serkanguzel
serkanguzel
Sat Nov 30, 2013 8:09 am
#1 by serkanguzel
With last version…
Example link ;
Alatoo 24 ; http://212.112.96.234/live/6001.flv
  • Sat Sep 01, 2018 7:50 am
Re: Why not open the FLV extensions.
What error you have? It is working on my pc.
  • Sat Sep 01, 2018 9:10 am
serkanguzel
serkanguzel
#3 by serkanguzel
No error. Black screen only…
  • Sat Sep 01, 2018 1:40 pm
#4 by Prog
Send me logs. Do you have audio?
  • Sat Sep 01, 2018 2:28 pm
serkanguzel
serkanguzel
#5 by serkanguzel
Logs folders; https://www.dosyaupload.com/msbR
No have audio.
  • Sat Sep 01, 2018 5:31 pm
#6 by Prog
Hm. And still no picture if you waiting 1-5 minutes?
  • Sat Sep 01, 2018 6:34 pm
serkanguzel
serkanguzel
#7 by serkanguzel
Yes. Very long waiting. But no video.
Do you still have picture in the latest version ? ( Alatoo 24 )
  • Sun Sep 02, 2018 8:00 am
#8 by Prog
Not understand why so different with my PC.
And no audio? Do you use x32 version?
  • Sun Sep 02, 2018 3:56 pm
serkanguzel
serkanguzel
#9 by serkanguzel
My PC software system; Windows 10 Pro 64bit
Installed ProgDVB; 32 bit PRO
  • Sun Sep 02, 2018 4:07 pm
#10 by Prog
Try select LAV for h.264 codec in ProgDVB settings.
  • Mon Sep 03, 2018 6:43 am
serkanguzel
serkanguzel
#11 by serkanguzel
Thanks. With lav decoder problem solved. :lol:
  • Mon Sep 03, 2018 9:45 am
Return to “IPTV”
  • It is currently Mon Jun 16, 2025 5:24 pm
