Re: Time Shift Buffer Overfill error !!
#16
Wed Jan 09, 2019 5:13 pm
No traffic and ProgDVB reconnect channel after 40 seconds.
No traffic, that makes since!
EDIT: I forgot to mention, the timeshift errors occurs while recording from an stable stream/channel aswell !!
Now that doesn't make any sense at all !?
Would it help this issue if progdvb shortens the time to reconnect !?
If so, can you change/code the delay between the signal/traffic loss and reconnection.
Or better yet implement that option in progdvb, so that we as user can change /adjust that reconnection delay per channel in the options from sheduled records ???
thanks
TD
Current Main System:
MOBO: Sabretooth FX990 R2.0
CPU: FX-8350BE@4,7Ghz
Cooling: NZXT x52
GPU: RX580 8GB
SSD: Samsung EVO 850 250GB
RAM: 16GB PC3-12800 Quad Channel
Monitor: MSI Optix G27C2
OS: Windows 10 x64 Pro
