Shedule error!
All of a sudden now , i get the following error when i try to shedule record ↓ !!!
First i have searched for answer arround the place like but no dice !!
Then i tried to un/install , gave all apps in dvbprog folder admin rights ... have installed it using "portable folder... and something for user rights" but allas!!
Odd thing is , after i get the error and close shedule window dvbprog starts recording emediatly !?
Using progdvbnetpro latest.
Logs in attachement.
EDIT: When i shedule record for every day or several day's a week planning it WORKS !! But it wont shedule One time record anymore !!
EDIT 2: okay, i found the "cause" of it... i get to see shedule errors ever since i changed power plan of my windows 10 !! When i set and activate sleep timer mode i GET THAT pesky ERROR !!
Odd, since i disabled all hibernate/sleep feauters in dvbprog and i dont use it in shedules neither !!!
oh well,
td
Current Main System:
MOBO: Sabretooth FX990 R2.0
CPU: FX-8350BE@4,7Ghz
Cooling: NZXT x52
GPU: RX580 8GB
SSD: Samsung EVO 850 250GB
RAM: 16GB PC3-12800 Quad Channel
Monitor: MSI Optix G27C2
OS: Windows 10 x64 Pro
Logs.7z
(13.81 KiB) Downloaded 145 times
Re: Shedule error!
Sun Oct 28, 2018 6:19 am
That message mean no rights for using MS scheduler. try start with admin righs
Hi prog,
Thats what i thought first too. But i have configurated all apps within dvbprog folder to start as administrator for ALL users / accounts , but that didn't worked !
fyi, It happends with both, x86 & x64 variant of dvbprog !!
However, i don't get no such error when i shedule for weekly or daily record, but the error shows only for a "once" sheduled record !??? Shouldn't i have gotten that error everytime when i tried to shedule something if it only was a matter of admin rights ??
anyway, like i said in previous posts. I dont know why, but it all started when i changend and edited power plan (sleeptimer) of my desktop !! Currently iam using Hibernate (hybrid sleep on), but as soon i used it in conjuction with an sleep timer i get that shedule error !? I have reproduced the error several times like this !!
many thanks in advance ,
regards,
michel
Cooling: NZXT x52
GPU: RX580 8GB
