Re: progdvb crash/exits audio setup !?!?!
#17
Thu Dec 27, 2018 7:06 am
Time index is not part of TS. Looks like no problem on ProgTV side.
For "What type of stream? Try push on pause and collect 20-30 seconds of traffic. " need url/link to channel or logs
Hi prog,
I have another rather small pile of logs for you attached in this mail.
It happend again on a h264/AVC / AC3 coded channel !! Progdvb tried to take preperations but resulted in Time Out Error ! NO VIDEO No AUDIO, no nothing !?
Now, you could be right and progdvb might not be at fault!!
But, i have checked the VERY SAME channel on my iptv box.. And, although i do GET VIDEO output on my iptvbox ..
I DID NOT GET Audio to hear from that channel on my iptvbox !!!
IS ↑that↑ the reason why progdvb is causing the Time Out errors , and time indexes of recorded streams get corrupted mayhap?
many thanks for looking into it anyway,
regards,
TD
Current Main System:
MOBO: Sabretooth FX990 R2.0
CPU: FX-8350BE@4,7Ghz
Cooling: NZXT x52
GPU: RX580 8GB
SSD: Samsung EVO 850 250GB
RAM: 16GB PC3-12800 Quad Channel
Monitor: MSI Optix G27C2
OS: Windows 10 x64 Pro
(9.03 KiB) Downloaded 70 times
