Prog Media Server Home & Windows Remote Desktop
Hello,
I use ProDVB server on my NAS running on Windows 7 for a long time. It is always started with /NoGraph. In the last time I noticed an issue which I didn't observed before. When I connect to the NAS using Remote Desktop connection, the connection in my ProgDVB client to the server is dropped and I can't connect anymore. When I check the ProgVDB server, Prog Media Server item is missing in the menu Service. When I change a channel on the server, the item appears in the menu and I can connect again.
The issue appeared in last days, I didn't change ProgDVB version. What I remember - I just installed OpenHAB + Java on the server. Can you help me please? Logs attached.
logs2.zip
(8 KiB) Downloaded 326 times
