    • Unanswered topics
    • Active topics
Recoding
Popski49
Popski49
Thu Mar 21, 2019 5:26 pm
Recoding
#1 by Popski49
Hi Prog, I have everything working beautifully, super app but only trouble I have is if I delete a recording I lose the function to record anything else.....please help
  • Sun Mar 24, 2019 8:34 am
Re: Recoding
Try select download folder for record.
  • Sun Mar 24, 2019 10:02 am
Popski49
Popski49
Re: Recoding
#3 by Popski49
Thanks for your reply...have tried selecting record folder still not working. If I reinstall apk everything works untill I delete a recording, any ideas?
Thank you
  • Sun Mar 24, 2019 11:07 am
Popski49
Popski49
Re: Recording
#4 by Popski49
Hi Prog, I have reinstalled Progtv and everything working perfect. If I need to delete a recording I do it from ES File Explorer and no problems.
Many thanks for a superb IPTV apk
  • Sun Mar 24, 2019 12:54 pm
Return to “ProgTV Android”
  • It is currently Sun Jun 15, 2025 7:09 pm
