SS2 USB + diseq
1 post
khaiweed
khaiweed
Thu May 10, 2007 11:54 pm
SS2 USB + diseq
#1 by khaiweed
Hi, I can't configure my Skystar 2 Usb Box with my Diseq motor. Is it that Skystar is not compatible with diseq????
if not, hich module should i configure to work the progdvb
thanx
  • Fri May 11, 2007 3:05 pm
1 post
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 3:29 pm
