freezing and not responding prog program and not the actual stream.
#1everything is up to date. but progdvb is freezing and not responding some of the times. other times it is working ok. also sometimes when you sear c\by name for a channel as you type name it will freeze and shutdown progdvb program. i am willing to send you logs but i do not know where they are at to be able to send them to you. i am using windows 10 computer which is up to date. thanks. also i would like to see more codecs already installed . thanks
