    • Unanswered topics
    • Active topics
ProgDVB programs are no longer recorded
Harry_41
Harry_41
Sat Aug 20, 2011 11:11 am
#1 by Harry_41
I use ProgDVB as a video recorder. However, programs are no longer recorded. The scheduled recordings simply remain in the list. The ProgDVBService service is running.
I would be very grateful for help.
  • Fri Dec 27, 2019 10:48 am
Re: ProgDVB programs are no longer recorded
Problem in scheduler or with simple recording also?
  • Fri Dec 27, 2019 10:50 am
Harry_41
Harry_41
#3 by Harry_41
If I record manually, everything works fine.
  • Fri Dec 27, 2019 11:11 am
#4 by Prog
May be some access problem. try use MS scheduler mode.
  • Fri Dec 27, 2019 11:26 am
Harry_41
Harry_41
#5 by Harry_41
It worked.
ProgDvb is always started in administrator mode. I do not understand that.
  • Fri Dec 27, 2019 1:37 pm
#6 by Prog
Service working in other login when ProgDVB. Some time not have permissions...
  • Fri Dec 27, 2019 2:14 pm
Harry_41
Harry_41
#7 by Harry_41
It used to be better with the records without a surface. The error rate was also lower.
  • Sat Dec 28, 2019 12:11 pm
Попробуйте пререлиз.
Prog, Mon Jul 07, 2025 3:07 pm
Странный формат. как xml но не xml. Зачем было такое делать... Но вроде не должно быть с ним проблем
Prog, Mon Jul 07, 2025 2:32 pm
Рабочая программа передач: https://raw.githubusercontent.com/dp247/Freeview-EPG/master/epg.xml Пробую загрузить - возник
kostan, Mon Jul 07, 2025 10:25 am
Re: ProgTV WinUI3
Плохо то, что в ПрогДВБ и ПрогТВ с включённым ПрогДВБЭнджином до сих пор нет звука e-ac3. Это совсем не редкий формат. И
kostan, Mon Jun 30, 2025 6:28 am
  • It is currently Mon Jul 07, 2025 5:03 pm
