    • Unanswered topics
    • Active topics
Codec H265
nandomartelli202
nandomartelli202
Sat Feb 15, 2020 8:10 am
Codec H265
#1 by nandomartelli202
Good morning. Is there a possibility to download the codec for watching videos in H265?
  • Sat Feb 15, 2020 8:15 am
Re: Codec H265
For example LAV is free and quite good
https://github.com/Nevcairiel/LAVFilters/releases
Some time codecs from your video card is best because support hardware acceleration.
  • Sat Feb 15, 2020 8:37 am
Return to “Modules”
Re: ProgTV 3.8.3 - Trail Peri…
Do you have license? In any case - try install previous version of ProgTV. I'll test it again tomorrow
Prog, Sun Sep 07, 2025 3:15 am
ProgTV 3.8.3 - Trail Period E…
On my Windows 11 machines, I am now getting this message in a pop-up box - WinLicense Your trial period has expired
MG317, Sat Sep 06, 2025 4:51 pm
Re: IPTV channel list issues
1. I changed the leading character to * and it sorts properly now. It seems you are removing leading . characters from t
noremorse57, Sat Sep 06, 2025 2:08 pm
Re: first response feedback
Thanks for feedback. It is more convenient to respond to text as in a video. 1. I am not can repeat first problem with
Prog, Fri Sep 05, 2025 4:21 pm
  • It is currently Mon Sep 08, 2025 10:52 am
