    • Unanswered topics
    • Active topics
Updated channels are listed in Root of list instead of folders
phunksouljah
phunksouljah
Tue Sep 18, 2018 3:13 am
#1 by phunksouljah
Whenever my provider updates the channel list (m3u), the updated channels are listed in the root of the playlist instead of being sorted in a folder. The only work around I've found is to disable the TV source and re-add it. Does anyone have any idea on how to fix this?
https://imgur.com/LZsxSmO
  • Mon Apr 20, 2020 2:11 am
Re: Updated channels are listed in Root of list instead of folders
Is it last version of ProgDVB? I fix that some time ago
  • Mon Apr 20, 2020 3:04 am
phunksouljah
phunksouljah
#3 by phunksouljah
I have 7.27.03. I'll update to the latest version. Thanks!
  • Mon Apr 20, 2020 5:10 am
Return to “IPTV”
  • It is currently Sat Jun 14, 2025 2:56 pm
