    • Unanswered topics
    • Active topics
Senderlogo Kanalliste
User avatar
Strong
Sun Jun 10, 2018 10:13 am
#1 by Strong
... wie oder wo kann man die Senderlogos von den channels abspeichern...
  • Fri Apr 24, 2020 5:14 pm
Re: Senderlogo Kanalliste
ProgDVB? You can put logos to ChLogos folder. Or setup links in m3u file.
  • Fri Apr 24, 2020 5:21 pm
User avatar
Strong
#3 by Strong
I don't want to insert them ... I want to save them ... to use them in open-atv :-)
  • Fri Apr 24, 2020 5:42 pm
Return to “German”
  • It is currently Sat Jun 14, 2025 2:52 pm
