    • Unanswered topics
    • Active topics
Best video and playback settings for amlogic based device (minix uh9)
famousstb
famousstb
Tue May 19, 2020 1:46 pm
#1 by famousstb
Does somebody knows what are the best settings for this device ?
For example:
Wich is the best ? openmax, ffmpeg,mediaplayer+, mediaplayer+ hls or omx.amlogic
Should i use deinterlace or not ?
Should i use 32 bpp video converter or not ?
Should i use open gl renderer or not ?
  • Wed May 20, 2020 10:38 am
Re: Best video and playback settings for amlogic based device (minix uh9)
It is quite depended form channels also. You can try different playback mode.
deinterlace - only for ffmpeg mode. 32bpp and opengl not important in most cases.
  • Wed May 20, 2020 10:41 am
famousstb
famousstb
#3 by famousstb
Ok i try mediaplayer+ its works. Is it the same as hw+ in mxplayer ?
Update: mediaplayer+ not best for me.
Openmax is just fine also exoplayer
  • Wed May 20, 2020 11:48 am
Return to “ProgTV Android”
  • It is currently Mon Jun 16, 2025 1:30 pm
