Support of CI+ Module on TT-Budget
Ernst1952
Ernst1952
Tue May 15, 2018 10:32 am
#1 by Ernst1952
One question.
Supports ProgDVB th separate CI+ Module of the card mentioned above ?
Thanks in advance
  • Sun May 31, 2020 8:40 pm
Re: Support of CI+ Module on TT-Budget
AFAIK this impossible. May be some plugin for some card reader.
  • Mon Jun 01, 2020 6:50 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 8:55 am
