    • Unanswered topics
    • Active topics
Record - split file
  • 1
  • 2
gartner
gartner
Wed Dec 01, 2010 8:42 pm
Record - split file
#1 by gartner
Hi
Is this feature gone?
Before I could split a recording by size or time.
Regards
Gartner
  • Sun May 31, 2020 9:27 pm
Re: Record - split file
ProgDVB? You can try this in record options.
  • Mon Jun 01, 2020 6:51 am
gartner
gartner
#3 by gartner
yes in ProgDVB
  • Mon Jun 01, 2020 9:49 am
#4 by Prog
What problem with this function?
  • Mon Jun 01, 2020 10:21 am
gartner
gartner
#5 by gartner
Under record. I dont see the function...
7.34.02
  • Mon Jun 01, 2020 3:03 pm
#6 by Prog
Do you use simple mode on mail page of settings?
  • Mon Jun 01, 2020 3:20 pm
gartner
gartner
#7 by gartner
No it's advanced...
  • Mon Jun 01, 2020 4:00 pm
#8 by Prog
hm. What TV sources used? Internet TV?
  • Mon Jun 01, 2020 6:09 pm
gartner
gartner
#9 by gartner
a TBS 8922 DVBS/S2 Tuner.
I tried uninstall it, reboot, and reinstall prog, but it is the same.
I have not used progdvb since the summer last year, and If I remember right, this options used to be there then.
  • Mon Jun 01, 2020 6:23 pm
#10 by Prog
But is it last version of ProgDVB?
  • Mon Jun 01, 2020 6:30 pm
gartner
gartner
#11 by gartner
Version 7.34.02
  • Mon Jun 01, 2020 6:39 pm
#12 by Prog
Please try prerelease
  • Mon Jun 01, 2020 7:29 pm
gartner
gartner
#13 by gartner
Thanks!
It's working now :)
  • Mon Jun 01, 2020 7:56 pm
gartner
gartner
#14 by gartner
Hi
I did a test record over night.
It does not split file by time. I set it to split by 60 min, but it was one large file.
It's works by size.then it splits..
  • Tue Jun 02, 2020 2:06 pm
#15 by Prog
Hm. I am very long time not test this function. Thanks for report.
  • Tue Jun 02, 2020 4:07 pm
  • 1
  • 2
Да, это довольно сильный краш тест. Может и повиснуть. Движковые и libvlc каналы лучше не смешивать. У них разные видео
Prog, Thu Mar 05, 2026 6:31 am
У вас при переключении каналов, когда включён LibVLC, зависает UI. Особенно если одновременно в одном списке, в одном ли
kostan, Thu Mar 05, 2026 5:06 am
Re: Проблемы с программою пер…
Как то странно. Можете мне m3u прислать и ссылку на гид для теста? Если лист платный, можно вырезать оттуда ключ, мне са
Prog, Tue Mar 03, 2026 2:46 pm
Re: Переключение каналов и из…
Если вы про недостающую точку в разрешении, то появилась идея - опубликовал в пререлизе. Проверьте пожалуйста и отпишите
Prog, Tue Mar 03, 2026 2:44 pm
  • It is currently Fri Mar 06, 2026 9:28 pm
