I have MadVR installed and i am trying to set it up on ProgDVB x64 but in the menu it’s showing as not installed, i am able to select it however and when i apply the settings i get a Video renderer creating error. It kind of works after the error but causes ProgDVB to show the error again sometimes when changing channel. I am using K-Lite Codec Pack version, is that the problem?
Would really like to have this running to improve the image quality, any help to get this working would be great
Re: Trying to set up MadVR
#3I am using x64 codecs, and i am pretty sure MadVR is x64 too. As i say it is working even if it's not showing as installed in ProgDVB. I am getting the Video renderer creation error when changing to certain channels.
#4In any case I am recommend test x32 version of app and codecs at first.
#5Hmmm it's the same in x32 version, does MadVR need to be installed in a particular folder?
#6No. In any folder. But of course must be registered in OS.
Do you use last version of madvr? I test it again in near days.
ps: MadVD not very stable working in ProgDVB and I am not use it every day.
#7Yeah i am using the latest version, it would be awesome if you had a look at it. Whenever you have the time of course. Would any log files from me be any help?
#9Ok, no problem. Another thing i have noticed with MadVR is you cannot change the aspect ratio, which can be annoying as some channels switch from 16:9 to 4:3. It doesn't do it automatically or if you change it manually in the menu
#10Checked madVR. It is really working. "Not installed" is bug on my side.
#11Ahh good stuff, any luck with the video renderer creation error? It seems to be only on certain channels and even then it doesn't pop up every time, only intermittently.
#13Here are the logs: https://drive.google.com/file/d/1VvnYzL ... sp=sharing
The channel still loads up fine after the error appears, you can just press close on the box
#14Try other video codec for mpeg2. Current codec not like connect to madVR.
#15i am using LAV, if i try others it either makes the error appear for every channel or some channels don't load at all.
