I have instaled ProgrDVB 7 Professional but works very slow and sometimes restart my PC . My PC have very good components.What you think I should fixed for working faster?After each click I need wait 1-2 minutes for take effeect. Thank you.I use windows 10 .
My PC resource are : Processor AMD Ryzen 5 3600 6-Core Processor 3.60 GHz , 16GB RAM, NVIDIA geforce GTX 1650
Please help me.
Thank you
Re: ProgDVB Professional 7work slow and sometimes restart my PC.
#2Try change video renderer in ProgDVB options. What video codec you use?
#3I use LAN video decoder and video renderer is EVR . But application work very slow from begining,when program start need wait 2-3 minutes for open after that is I click Manual search again I need wait 2-3 minutes until tab is open . PC sometimes is restart when I open ProgDVB ,before program start PC restart. What video renderer I need chosse ?
#4Also , I can t change it because when click Aply, app blocked and " Not responding "
#5Manual search without channel playback? Must be open for 1-5 seconds. Depended from tuner.
What DVB device you use?
#6Yes,just manual search ,for every click I need wait 1-3 minutes for execute.I receive error " Not responding " and wait .I m using TBS5927.
#7Very long. Try update DVB driver. Also possible change Settings-[device name]->mode to microsoft
#8I put a screenshot.Just 1 click
there and I need wait 1-3 minutes for that tab open .
#9Try uninstall ProgDVB and install without DVB device in installer. After that you can add DVB in TV sources dialog.
#10Thank you very much for your support . Now working better after I made all your sugestion. Have a nice day .
