    • Unanswered topics
    • Active topics
Hauppauge WinTV HVR-5525 - No Signal error.
Re: Hauppauge WinTV HVR-5525 - No Signal error.
#1 by Prog
Try reinstall and scan channels again. Do you have channels after scanner?
  • Wed Aug 09, 2023 5:35 am
Youtube not important and not need large screens. Still wait answer. Do you have channels after scanner?
Check mode in Device options in ProgDVB. Diseq request correct mode/api
  • Wed Aug 09, 2023 8:02 pm
#3 by Prog
Try uninstall ProgDVB and install again. Without import/export data.
  • Thu Aug 10, 2023 7:04 am
Fikret Turedi
Fikret Turedi
Sun Feb 18, 2024 8:17 pm
#4 by Fikret Turedi
problem solved. Thank you very much.
  • Thu Feb 22, 2024 6:47 pm
Return to “Hardware”
  • It is currently Sat Jun 14, 2025 12:08 am
