deleting a playlist
ravo1957
ravo1957
Thu May 20, 2021 3:29 pm
deleting a playlist
#1 by ravo1957
i can't see anywhere how to delete a playlist in progtv or prog dvb only to disable it. Can you tell me how please.
  • Fri May 03, 2024 10:38 pm
Re: deleting a playlist
"disable it"="delete".
What not good with this function?
  • Sat May 04, 2024 5:15 am
ravo1957
ravo1957
#3 by ravo1957
the playlist is still in the list even after it's been disabled. I want it gone completely.
  • Sat May 04, 2024 2:22 pm
#4 by Prog
Do you mean channel list in ProgTV interface? Must me removed after the user disable of the source.
What source type you use?
  • Sat May 04, 2024 4:14 pm
ravo1957
ravo1957
#5 by ravo1957
m3u
  • Sat May 04, 2024 7:19 pm
Return to “ProgTV Android”
Email sent.
  • It is currently Sat Jul 25, 2026 11:46 pm
