    • Unanswered topics
    • Active topics
Hauppauge WinTV HVR-5525 is very fast with "stream reader".
Fikret Turedi
Fikret Turedi
Sun Feb 18, 2024 8:17 pm
#1 by Fikret Turedi
In ProgDvbx86 -7.63.02 version, my Hauppauge WinTV HVR-5525 DVB-S2 Card works very fast and stable with the "stream reader" option. h was very pleased. I hope the "stream reader" option will come to ProgDvbx64 - 7.xx version as well. Good luck in your work. Thank you
  • Fri Sep 27, 2024 4:09 pm
Re: Hauppauge WinTV HVR-5525 is very fast with "stream reader".
Do you know x64 StreamReader?
  • Fri Sep 27, 2024 7:59 pm
Fikret Turedi
Fikret Turedi
#3 by Fikret Turedi
No, unfortunately I don't know.but I wish I could learn
  • Fri Sep 27, 2024 8:32 pm
#4 by Prog
I am do only wrapper for StreamReader. CrazyCat is author of StreamReader. You can try ask him about h64.
  • Sat Sep 28, 2024 7:42 am
Return to “Hardware”
  • It is currently Sat Jun 14, 2025 12:09 am
