Hello,
Would it be possible the width of the EPG full discription pop-up window of a program/movie, to be the half of the width of the ProgTV window?
Watching in full screen mode and on big TV it is very inconvenient to read it from the one to the other sides of the TV.
PS - How can I insert a picture?
Thank you,
Nicky
Re: EPG full discription pop-up window of a program/movie
#2Do you mean description of current channel or all channels? You can try "right" on channel in channel list.
#3I mean of the description of the current channel.
I can't upload picture to show it.
Thanks
Thanks
#4What error message when you upload picture? Many pictures already in forum....
Confusing for the user, and it's unclear where to post this.
Many functions are not always a good thing.
#5When I hit the "Insert image" button I get only this text inserted:
I see that there are pictures in the forum but I can't figure it out how I can upload mine.
What button (seems it is not the Insert image one) or link/procedures I shall hit/follow?
#6Finally, I got it how to upload picture, so here is what I meant - when the description of the channel is long it spreads on the full size of the screen, which is inconvenient when watching on a big TV. If possible to limit the max width to the half of the screen will be good.NickyNSS wrote: ↑Mon Feb 24, 2025 9:19 pmHello,
Thank you,
Nicky
Thank you,
Nicky
#7I am mark this. Half size is too small for long text but some limit is possible.
#8Yes, any limitation will be a good solution.
#9With applied limitation, viewing of a long description of a channel on a big screen is much more convenient now.
Thank you.
Thank you.
