Interface super tiny, and text either very tiny or half hidden
TiviViewer
TiviViewer
Wed Jul 30, 2025 9:23 am
#1 by TiviViewer
Hello,
I just installed on my computer, and launched it, but the text is either half hidden, or almost unreadable because it's too small. I have a 4K, 24-inch monitor, and in Windows settings, I use a 200% zoom that applies to all applications.
Could you help me please?
Thank you.
  • Wed Jul 30, 2025 9:28 am
TiviViewer
TiviViewer
Re: Interface super tiny, and text either very tiny or half hidden
#2 by TiviViewer
I tweaked the Windows settings to adapt scaling, but now the text labels are in normal size, however text is pixelated:
  • Wed Jul 30, 2025 10:53 am
#3 by Prog
Do you mean menu text? Try ProgTV skin in ProgDVB but best if <200% scale.
I am recommend ProgTV3 for best hi-res support.
  • Wed Jul 30, 2025 1:32 pm
Return to “ProgTV Windows”
Форум лучше же стал? Ну пока работает. Пусть хоть недельку поработает, тогда можно будет сказать.
Mostwanted, Mon May 25, 2026 6:14 pm
Prog, Mon May 25, 2026 5:48 am
Надеюсь в следующей версии заработает.
Prog, Sun May 24, 2026 6:39 pm
Две. Pause/play и "всегда пауза". У меня так же любая - работает. ps: Не люблю слово "любой". Когда пользователи пишу
Mostwanted, Sun May 24, 2026 3:59 pm
  • It is currently Sun May 31, 2026 2:02 am
