Which EPG's are there available that are compatible with progDVB?
Which one do you recommend?
I have a Twinhan remote & a Microsoft MCE remote, if there is any EPG that will work with either remote out of the box that would be even better, although I can use a program like Girder if required.
Module compatibility depends on ProgDVB versions.
For 4.x versions with old engine, you can try RelictEPG instead of the internal one.
For more modern versions, I don't know any alternative.
