EPG
#331
Omihalcon wrote:
EPG:
Work OK but some characters code are wrong: characters " ù " " è " are displayed respectively with " ų " and " č ". The vowels " à " and " é " are correct.
UPDATE:
I'm from Italy: the standard set of characters code is central europe? In this post
viewtopic.php?p=12808#12808 the chars are lithuanian simbols....
#332
Omihalcon wrote: And the last:
On unistallation in all release the file in C:\ProgDVB.ini won' t delete.
SAME for release 6.04.04. the file C:\ProgDVB.ini isn't delete.
I'm installing release 6.04.06
My configuration: Athlon XP 3000+/1GB RAM/Pinnacle PCTV 310i Hybrid/Geforce Ti 4200[/quote]
#333
ProgDVB v6.05 x64 Version with Vista Ultimate x64/nVidia 9800 GTX
2 Crashs (everytime, reproduceable)
Doubleclick on the Statusbar/Programm Information or Service > EPG
System.ArgumentException: Font 'Arial' does not support style 'Regular'.
at System.Drawing.Font.CreateNativeFont()
at System.Drawing.Font.Initialize(FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont)
at System.Drawing.Font..ctor(String familyName, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet)
at ProgDvbNet.EpgForm.()
at ProgDvbNet.EpgForm..ctor()
at ProgDvbNet.EpgForm.Show(IWin32Window owner)
at ProgDvbNet.MainForm.(Object , EventArgs )
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Label.WndProc(Message& m)
at IPDev.Skins.SkinLabel.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3074 (QFE.050727-3000)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
ProgDvbNet
Assembly Version: 6.5.0.0
Win32 Version: 6.05
EngineApiWrapper
Assembly Version: 1.2.6.0
Win32 Version:
msvcm80
Assembly Version: 8.0.50727.3053
Win32 Version: 8.00.50727.3053
CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.3053_none_88e044e32fae7230/msvcm80.dll
System
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.0.2.0
Win32 Version: 1.0.2.0
IPDev.Skins
Assembly Version: 1.3.8.0
Win32 Version: 1.3.8.0
ProgDvbNet.CC
Assembly Version: 1.0.4.0
Win32 Version: 1.0.4.0
CodeBase: file:///C:/Program%20Files/ProgDVB/ProgDvbNet.CC.DLL
ProgDvbNet.EPG
Assembly Version: 1.0.5.0
Win32 Version: 1.0.5.0
ProgDvbNet.Win
Assembly Version: 1.0.0.0
Win32 Version:
System.Xml
Accessibility
System.Design
System.Drawing.Design
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
enabled.
For example:
<configuration>
</configuration>
2nd... Mouse-Wheel up/down to change the Volume > Sorry, German Error Message but i think its ok ;)
dw20.exe - Fehler in Anwendung.
Die Anweisung in 0xef3fecd2 verweist au Speicher 0x00000000. Der Vorgang read konnte nicht im Speicher durchgeführt werden. OK/Cancel. ProgDVB Crashed.
thanks, and sorry if the bugs are reported twice :)
EPG window has Alzheimer Desease
#334
6.05: EPG window has Alzheimer Desease.
When closing EPG window and reopen it again, it has forgotten its position and size.
Btw: timer window should also remember size, position and column positions and widenesses.
#335
os: windows 7 x64
progdvb: 6.05.01 x64
dvb: AVerMedia AVerTV DVB-S Pro II (706)
I have annoying problem while changing volume via usb mouse wheel up and down. if you change volume a bit faster it gives not resonding error and shutting down. i also formatted the system and try with another dvb card (twinhan 1020a) but same result.
I cannot use gbox plugin with this version. am i making a mistake? the plugin is gbox 1.1 its already in plugins folder but in progdvb's plugin settings shows nothing.
Thanks.
[url]http://www.oyunmaniac.com[/url]
#336
That plugin seems to be a 32bit version, but 64bit ProgDVB requires 64bit plugins.
Anyway,that kind of plugin is not to be discussed here,for legal reasons.
Read the board rules.
Regarding that mouse wheel / volume error, who or what "gives" that error?
What mouse and driver / software for it are you using?
Please give full details, to enable people helping you.
#337
dw20.exe, seems to be from Microsoft's Framework... MouseDriver/Mouse? Its a Logitech MX518.
#338
Juergen wrote:That plugin seems to be a 32bit version, but 64bit ProgDVB requires 64bit plugins.
I am using creative fatality 1010 mouse but with standart mouse drivers. here is the screenshot of error while changing volume:
I installed progdvb x86 version for using x86 version plugin. but it does not open the channels. i can see the channel signal and quality is same as x64 version but the screen doesnt shows the channel and sound neighter. its not about codecs i tried all codecs but didnt work.
Ps: i tried it with another mouse but same error appears.
#339
ProgDVB 6.05.01 minor bug:
Right-Clicking on the system tray icon, then chosing "Exit" has no effect.
Shouldn't be too much work to fix this. :roll:
#340
nuschii wrote:ProgDVB 6.05.01 minor bug:
new version not for only one fix but Prog wait for others or adding new things or any thing like that.
#341
its interesting;
if i use x64 version i can watch the channels, but in x86 version, last channel i was watch in x64 version, only it can be watchable, if i searched for new channels, its find only last channel i was watch in x64.
avermedia a 706 & win7 x64
#342
its not a bug but 6.05.02 x64 version tries to install on program files (x86) folder.
mouse wheel volume change bug still happens, x86 still cant find channels. finds only last channel i watched from x64 version.
#343
EzerchE wrote:its not a bug but 6.05.02 x64 version tries to install on program files (x86) folder.
Merhaba Gürkan ,
I use x64 version under Win7 and it works pretty well , and installs under Program Files\ , so I don't see any problem.
But it doesn't run any Plugins ...
my problem is :
In x86 version is pretty chaotic under win7 x64 . Lots of crashes , freezes. And after a couple of attemps of running it, it somehow locks the DVB card and even x64 version can't run anymore without rebooting the PC. Is there a way to solve it?
#344
1-properties for Audio Processor Not Work (File>properties>Audio Processor>properties)
When I press properties Button I Get this error:
at (Void* , * )
at ..(IntPtr , Control )
at ProgDvbNet.MediaPropertiesForm.(Object , EventArgs )
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
mscorlib
Win32 Version: 2.0.50727.1434 (REDBITS.050727-1400)
ProgDvbNet
Assembly Version: 6.5.2.0
Win32 Version: 6.05.02
EngineApiWrapper
Assembly Version: 1.2.7.0
Win32 Version:
msvcm80
Assembly Version: 8.0.50727.1434
Win32 Version: 8.00.50727.1434
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.1434_none_d08b6002442c891f/msvcm80.dll
ProgDvbNet.bc
System
IPDev.Skins
Assembly Version: 1.3.10.0
Win32 Version: 1.3.10.0
System.Drawing
Accessibility
ProgDvbNet.EPG
ProgDvbNet.CC
System.Xml
ProgDvbNet.Win
Win32 Version:
System.Design
enabled.
For example:
<configuration>
</configuration>
2-Alt+click(Open In new window) not work properly
3-Take snapshot only works on Wide screen Channels (Aspect Ratio = 16:9)
* I use Win Vista-32bit SP1 Ultimate & SkyStar HD2 *
#345
1. What button? AP?
2. PIP possible only on same transponder or on different devices.
3. What video render? What you have on 4:3?
